Loose P.S. belt or when making tight turns, the pump will screech or wine if the steering wheel is held tightly as far as the wheel can go.
Check for a loose belt and back off a tad during tight turns where the P.S. pump is stressed / maxed out.
Also, low fluid can cause issues as well as contaminated fluid that needs to be changed.
