Are oil filters built to use oil viscosity their original application calls for? As in my jeep calls for a PH16(fram)/14670(purolator) sized filter. my jeep also calls for a 30wt oil, does this mean the ph16/14670 sized filters are made to use 30wt oil? does viscosity affect oil filters at all? What if I am now running an oversized filter spec'ed for a different vehicle? are the bypass valves still set for the same pressure? even if the vehicle applications call for a different weight oil?
not that its possible but, what if you ran a filter commonly used for 0w-20 oil and some how used it on an application that called for 15w-40 oil. will the bypass valve open up immediately expecting thin 20wt oil? or is this not how it works at all? or does this mean we should be using filters close to the viscosity their original application calls for? what if someone with a vehicle that requires a 20wt puts in a 50wt oil, is their filter bypass going to open up more frequently then it should because of the excessive visocity?
I guess I can't find a clear answer googling it so I'm asking here
