So I got myself this nice 1996 Ford Bronco 5.8L...and need to change the transmission fluid. Already got the Ford filter and seal.
At my local Walmart, I found the following ATFs:
Valvoline MaxLife DEX/MERC ($16.97 per gal)
Valvoline DEX/Merc ($16.87 per gal)
Castrol Transmax DEX/Merc ($17.68 per gal)
I haven't checked the local parts stores, but I bet I can get Mobil 1 ATF, etc. I also have a Chevron Lube dealer close by...
Which one should I get? I rather have some really good stuff, so the transmission will not get mad at me during 4wheeling, etc.
Interestingly, the Castrol Transmax DEX/Merc specifically mentions 1983 to 1996 Ford vehicles, unless it calls for Type F. And also states not to use when MERCON V, Mercon SP or Mercon LV is required. See below... So is this one "made for" my E4OD?
