2011 WRX - PU 5w30SN - 7405Miles
KHP
Reno, NV
I would like to share my latest UOA. 7,405 mile interval and 8 month service. The only thing that starting to concern me is the insoluble percentage trending up. Oil filter used is OE Subaru blue can. I guess I'll keep an eye on it on my upcoming interval cycle.
I'm currently running Purolator PureONE oil filter so we'll see if that makes a difference.
Code:
Miles on Oil -------- 7,405 ------ 7,480 ------ 7,538 ------ 3,744 ----- 2,718
Miles on Unit 29,925 22,520 15,040 7,502 3,758
Sample Date 04/05/13 08/12/12 02/04/12 07/23/11 03/12/11 Unit Universal
Make Up Oil added ---- 0Qts ------- 0Qts ---- 0.75Qts ------- 0Qts ------ 0Qts Averages Averages
Aluminum ---------------- 5 ---------- 4 ---------- 5 ---------- 4 --------- 5 -------- 5 --------- 4
Chromium 1 1 1 1 0 1 1
Iron 13 12 16 17 13 14 9
Copper ------------------ 4 ---------- 6 ---------- 8 ---------- 8 --------- 7 -------- 7 --------- 8
Lead 0 0 0 0 0 0 4
Tin 0 0 0 0 5 1 1
Molybdenum ------------- 55 --------- 52 --------- 64 -------- 109 ------- 247 ------ 105 -------- 74
Nickel 1 1 1 0 0 1 0
Manganese 1 3 0 0 1 1 1
Silver ------------------ 0 ---------- 0 ---------- 0 ---------- 0 --------- 0 -------- 0 --------- 0
Titanium 2 2 2 3 0 2 0
Potassium 4 3 5 2 0 3 2
Boron ------------------ 47 --------- 51 --------- 34 --------- 62 -------- 21 ------- 43 -------- 48
Silicon 6 6 8 10 18 10 11
Sodium 5 6 31 38 2 16 27
Calcium -------------- 2549 ------- 2175 ------- 1155 ------- 2678 ------ 2186 ----- 2149 ------ 2083
Magnesium 36 101 639 19 11 161 305
Phosphorus 758 624 660 789 706 707 783
Zinc ------------------ 927 -------- 752 -------- 786 -------- 936 ------- 741 ------ 828 ------- 932
Barium 0 0 0 0 0 0 0
Values
Should Be*
SUS Viscosity @ 210F - 59.3 ------- 57.9 ------- 55.2 ------- 56.4 ------ 53.9 55.8-65.2
cSt Viscosity @ 100C 10.02 9.62 8.83 9.19 8.46 9.3-12.5
Flashpoint in F 405 400 405 385 400 >365
Fuel % ---------------
Antifreeze % 0.0 0.0 0.0 ? 0.0 0.0
Water % 0.0 0.0 0.0 0.0 0.0
Insolubles % ---------- 0.4 -------- 0.3 -------- 0.3 -------- 0.2 ------- 0.2 -----
TBN 2.6 2.4 3.6 >1.0
TAN 3.0 5.0 5.0
ISO Code ------------ PU5W30SN --- PU5W30SN -- M1EP5W30SN - M1EP5W30SM - MbilCln5K5w30SM
* THIS COLUMN APPLIES ONLY TO THE CURRENT SAMPLE
You're probably right at the limit of the OEM oil filter (or any non extended oci filter) with your oci. OEM air filter?
-Dennis
-Dennis
Yeah I'm using OE Subaru air filter. Last air filter was switched out at ~25,000 miles.
I initially had an OE oil filter installed for my current cycle. Then someone here pointed out that Subaru/Fram recalled the OE oil filter that I installed. The OE oil filter was immediately replaced by PureOne filter the day after the oil change.
The filter change was by coincidence. This maybe a good thing as now I can see if a "higher quality" filter will make a difference on my insoluble numbers.
