".......John Scott has invented a tire with a constantly variable diameter, according to his patent. In other words, they slant. The inside diameter of the tire is less than the outside diameter and so the tread surface slants from sidewall to sidewall........"
"...........Because the tire is not being forced through a turn but rolling that way naturally it seems to get much better grip, better response and better subjective feel, not to mention less rolling resistance, less wear, less tread scrub and far less heat generation............."
http://tires.about.com/b/2013/04/12/the-sense-filled-rantings-of-john-scott.htm
