Windstar 2001 AC Low and High pressure reading
by pinjc
07/27/16 09:28 PM
Vacuum Pump Oil for rotary vane pumps.
by bunnspecial
07/27/16 09:22 PM
ST dino oil realistic OCI
by OILGEEK27
07/27/16 09:06 PM
Gas grills
by RN89
07/27/16 08:43 PM
Supercharged Subaru BRZ
by clinebarger
07/27/16 07:52 PM
Side can opener ?
by ST2008
07/27/16 07:48 PM
Pennsoil ULTRA not available
by JXW
07/27/16 07:41 PM
2005 Civic randomly stalls when taking off from a
by Avery4
07/27/16 07:36 PM
2003 Saturn L200 oil choice
by car51
07/27/16 07:30 PM
Good hour meter for small engines?
by motor_oil_madman
07/27/16 07:07 PM
2001 Chevy S10 V6 misfire...
by Blang
07/27/16 07:02 PM
Oil level and rpm
by mjoekingz28
07/27/16 06:59 PM
rummy, OILGEEK27, pinjc, Lee_C, cottoncuz4
58626 Registered Users
88 registered (Avery4, AIRJAC3, 2015_PSD, ABerns, 3800Series, 7 invisible), 1685 Guests and 10 Spiders online.
58626 Members
66 Forums
252339 Topics
Page 1 of 2 1 2 >
#2971766 - 04/13/13 07:02 PM 2002 Avalon-Original coolant. Change out to?
FXjohn Offline
Loc: NE Indiana
Original Toyota fluid, or change out to regular G05 coolant, etc?
advice appreciated.
#2971775 - 04/13/13 07:13 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
Chris142 Online   content
Loc: apple valley, ca
Id stick with the toyota coolant.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2971788 - 04/13/13 07:27 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
LeakySeals Offline
Loc: MA
According to the MSDS compatible aftermarket coolants are Zerex Asian and Peak Global Lifetime both sold at Napa. Zerex Asian is the correct color, PGL is a chameleon that changes color (sort of). But I'm having such great luck using Toyota Red LLC in the Camry in my signature I won't change away from it. Not one single replacement part so far. I do a 4 qt drain and fill every 50k, clean and top off the expansion tank once a year or whenever its low. Toyota red LLC is concentrate so once you mix 50/50 with distilled you will have 2 gallons. 2 gallons makes the sticker price not so bad.
02 Camry XLE 2AZ-FE 348k M1 HM 5w30
06 Escalade 135k. M1 5w30
#2971815 - 04/13/13 07:49 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
FXjohn Offline
Loc: NE Indiana
This is my mother's car. I guess I'll just have her have the toyota dealership do it.
#2971827 - 04/13/13 07:57 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
LeakySeals Offline
Loc: MA
They are going to charge her some ridiculous price. Its easy to drain and fill on that car. You can buy the gallon at the dealer for approx $28 a gallon ($14.50 per gallon mixed 50/50 distilled) There is a hand tight plastic drain plug at the bottom of the radiator to let coolant out. I can tell you how to do it if you want.
#2971847 - 04/13/13 08:08 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: LeakySeals]
Doog Offline
Loc: North Coast
I use the Toyota long life pre-mixed coolant only. It is $24/gallon but it is excellent and compatible with what she has in there. You can drain and fill the radiator really easily and just re-fill. The hardest part is removing the plastic underbody panel.
The difference between a beer and your opinion is that I asked for a beer... well except for just now..:-)
#2971882 - 04/13/13 08:34 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
Astro14 Offline
Loc: Virginia Beach
$28 a gallon? ouch...I just bought 2 gallons of Mercedes coolant for $22 a gallon...hard to believe that the MB dealer is cheaper than the Toyota dealer...
32 Packard 15W40
90 4Runner 10W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W40 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
16 Tundra 1794 TGMO
#2971939 - 04/13/13 09:36 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: Astro14]
LeakySeals Offline
Loc: MA
Toyota LLC is concentrate. Once mixed 50/50 with distilled you get 2 gallons = $14.50 a gallon.
#2971965 - 04/13/13 10:42 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: LeakySeals]
FXjohn Offline
Loc: NE Indiana
I'm all ears here.
#2972135 - 04/14/13 07:29 AM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
LeakySeals Offline
Loc: MA
OK. I attached a video. Its a newer Avalon, not very descriptive but give you an idea of what to expect. Will add some details.
Before opening the drain, open the radiator cap to relieve pressure to the system.
As you can see in the video your unscrewing the drain, but not all the way. This allows the coolant to drain out the small drain spout, not splash all over the place.
Depending on what you catch the coolant in, you may have to jack the car up a little bit to make room for the container under the coolant drain spout. In the video he's using a standard oil drain pan so no need to jack the car. Thanks to the drain spout I can go directly to a jug, so I lift the car with a floor jack to make room.
The expansion tank is most likely the same as the video and my Camry, not bolted on. Just lift it off the slide bracket for cleaning.
You should get 4-6 qts of fluid on the drain. Once you dilute the Toyota LLC red concentrate 50/50 with distilled water (NOT spring water) from the grocery store you will have 8 qts of coolant. Enough for the drain and fill, refilling the expansion tank, and some top offs.
Important step not mentioned in the video - After you tighten the drain, refill the radiator and the expansion tank, don't put the radiator cap on yet. At this point start the car without the cap, but have it ready to put on. You will see the coolant flow, maybe drop a little. Add more coolant to the radiator. After about 30 seconds you will see the coolant start to rise as the engine warms up, pushing air out of the system. Just before the coolant overflows, put the cap back on.
Let it warm up and watch the temp gauge. Your watching for the temp to stabilize at or below its prior setting, which means the thermostat opened and the system is functioning properly.
Does this get it all? No, there is a small amount of residual. But thats ok, the system expells any junk into the expansion tank. Clean and refill expansion tank when it gets low or once a year. Your good for another 3-4 years/50-60k on the drain. Then do it again. Could you go longer? Yeah but that seems to be the tipping point for me anyways. And I havent replaced anything with this method.
#2972515 - 04/14/13 02:30 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
FXjohn Offline
Loc: NE Indiana
thanks, leaky seals
#2979753 - 04/21/13 01:15 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
ChiTDI Online   content
Loc: Chicago IL
Did you change water pumps when you had the timing belt done?
You might not have the original coolant in there if you did.
Just a thought.
#2986746 - 04/27/13 08:44 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: ChiTDI]
FXjohn Offline
Loc: NE Indiana
Just a thought.
huh? where did this come from?
#2989455 - 04/30/13 03:02 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
Loc: Chicago IL
Just a thought.
From your original post. If your car had a water pump changed, like during a timing belt job, the coolant may not be OEM.
They may have used OEM red and correctly mixed it with distilled water, or incorrectly used pink OEM, or used some other fluid.
#2989779 - 04/30/13 08:21 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: ChiTDI]
FXjohn Offline
Loc: NE Indiana
Just a thought.
it's never had any kind of work done whatsoever. barely 50,000 miles on it
Page 1 of 2 1 2 >
