Best spark plugs?
by jk_636
10 minutes 50 seconds ago
Recoil, .380 versus .32?
by bobbob
36 minutes 55 seconds ago
Winter + Slightly off concentration of glycol
by nobb
52 minutes 59 seconds ago
Good synthetic oil for ford transit ecoboost?
by Jetstreamz06
58 minutes 10 seconds ago
Reuse fram XG for 1 more O/C?
by gabriel9766
Today at 07:21 PM
Supertech in the Mid South
by tony58
Today at 07:06 PM
Smoke Machine Substitute?
by Ducked
Today at 06:45 PM
Gallon jugs of MMO $4 @ WM
by sw99
Today at 06:43 PM
55k air filter replacement w/ pictures
by Vern_in_IL
Today at 06:38 PM
old B52 movie...
by Tuffy1760
Today at 06:18 PM
ST 5w30 ok for 11' Impala 3.5 engine
by car51
Today at 05:37 PM
small air compressor greasing
by friendly_jacek
Today at 05:00 PM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
117 registered (andyd, 2015_PSD, Abakev, 15SilvyEcotec, 01rangerxl, 8 invisible), 1707 Guests and 320 Spiders online.
57758 Members
66 Forums
248327 Topics
Page 2 of 2 < 1 2
#2396287 - 10/04/11 05:44 PM Re: 2T oil in Diesel to improve lubricity [Re: bullwinkle]
2cool Offline
Loc: Delaware
I run 1oz/gal. in my 7.3 Ford and VW TDI. The butt dyno says it idles smoother, seems to rattle less under load up a hill, but has no measured effect on economy. I do it because I AM A BITOGER!!!!!!
#2741292 - 09/11/12 11:37 PM Re: 2T oil in Diesel to improve lubricity [Re: drop]
FrankieFX Offline
Loc: Ontario
Running used motor oil with in diesel is terrible idea. No profit generating company would ever conceive the notion.
Diesel engine use high pressure in the injection system to maintain efficiency and risking clogging these with contaminants and metal particles is bad idea.
Also the HFRR lubricity test with used motor oil shows almost no benefit.
I worked with oil and gas companies that run diesel engines 24-7 at full load and consulted on reliability. There are companies producing plant derived anti-friction esters that perform with 55% score at crazy ratios of 200 ppm. That a 1/4 oz per 10gal and this is what is being used in big heavy industry.
Also using motor oil in a diesel engine will increase cylinder and exhaust heat. Potentially 5-10% due to the slow burn. Friction additive in motor oil do not burn well and will deposit. 2-cycle additive are very different and would be better choice between the two.
Throwing a big mess in your fuel also reduces fuel economy. The less you goo it up the better output you will get. Oxygen needs to move trough your fuel droplets, otherwise you get a pyle of soot.
There is company call Lubriflux and their main product is DieselFlux. Its being used on petroleum rigs and by far the most lubricative product we tested. It was 1oz per 10gal but cut component wear in half. I'm not sure if they sell to the public but might be some thing to check out.
Nissan 350Z - Red Line 5w30
Chevy z24 - Valvoline high mileage 5w30
Puch maxi moped Lubriflux 2charge 2-cycle
#2741620 - 09/12/12 11:25 AM Re: 2T oil in Diesel to improve lubricity [Re: FrankieFX]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Looked up the Diesel Flux-$250 per GALLON!?! I'll never complain about the price of Power Service nor MMO ever again!! At that price, injectors would be cheaper!
#2769359 - 10/11/12 01:05 AM Re: 2T oil in Diesel to improve lubricity [Re: drop]
AVB Offline
Loc: Georgia
I have been told that hydraulic fluid is a good diesel additive. They claimed it adds sulfur to the fuel. This is third hand information supposedly recomended by a well known diesel shop.
#2963933 - 04/05/13 10:56 PM Re: 2T oil in Diesel to improve lubricity [Re: drop]
morris Offline
Loc: ks, wichita
the test by the diesel place. is not done well in my opinion. 1. each lube is used at a different ratio. 2. then at the end this is,posted.::::::::::::::::::::::::::::::::::::::::::::::::::::::::
Products 16 through 19 were found to cause the fuel/additive blend to
perform worse than the baseline fuel. The cause for this is speculative. This
is not unprecedented in HFRR testing and can be caused by alcohol or other
components in the additives. Further investigation into the possibilities
behind these poor results will be investigated.
Any additive testing within +/- 20 microns of the baseline fuel could be
considered to have no significant change. The repeatability of this test allows for a
+/- 20 micron variability to be considered insignificant.
::::::::3. is speculative.? 4. and the test is done with a ball bearing. not pistons, valves ect. in my opinion the test has meaning only in very narrow range of material.
#2963993 - 04/06/13 01:49 AM Re: 2T oil in Diesel to improve lubricity [Re: AVB]
Shannow Online   content
Loc: Oz
sulfur isn't the issue, it's the things that are taken out, or molecularly changed when the fuel is desulfurised.
I can send you a block of elemental sulfur, incidentally, it was most probably obtained from desulfurisation of oil at a refinery...which has dropped the price to only a couple of hundred bucks a tonne
edit...just for interest, the cockatoo yellow mountains of sulfur at refineries are pretty amazing...look at link for a pile of prilled sulfur, bigger than football fields.
http://www.airphotona.com/image.asp?imageid=3874
Edited by Shannow (04/06/13 01:57 AM)
#2970741 - 04/12/13 04:53 PM Re: 2T oil in Diesel to improve lubricity [Re: FrankieFX]
skellyman Offline
Loc: Mo.
I think it odd Cummins offers the Sentinal system on it's Diesels, it puts used oil in the fuel system an adds new fresh HDEO to the engine from a tank.
Will wonders never cease.
Edited by skellyman (04/12/13 04:57 PM)
I sold and used Skelly Supeme an Supreme Plus
Now I use Mobil Oils
99 Dodge I-6 Delvac 15w40
01 PT Cruiser Mobil Super 5w30
Page 2 of 2 < 1 2
