Just returned from the farm where the soon to be world famous "Luv" machine and I had a super fantastic time hauling super huge amounts of brush and tornado debris to the burn pile.
For those who have not followed the saga, the "Luv" machine is a 1986 Chevy Astro van, 4.3 V-6 with a 700R4 automatic transmission. Vehicle does not see road service but is used as farm mule to haul, push, pull and transport tools and debris around the farm.
Transmission has a severe leak from front main seal behind the torque converter. Current transmission fluid fill is a mixture of USED dexron III/M (I flushed my '93 Taurus and my 95 Olds and am using that as top off fluid). I've also been using some ancient 40 weight that has been in my shed for years, so about every 4th or 5th quart is 40 weight, the other quarts are DexIII/M that I pulled out of the Taurus and Olds.
Bright and early Monday morning, I filled transmission with DexIII/M, (two quarts to fill). Then I added two bottles of "Bar's Leaks" Transmission Stop Leak Concentrate." I used two bottles because one 11 oz bottle treats 10 quarts and my tranny is leaking pretty bad so I decided two would be better.
"Bar's Leaks" Transmission Stop Leak Concentrate" is a clear liquid and while not a heavy fluid, is it not thin either - (in other words, it's not "Sea Foam Trans Tune thin nor is it "Lucas Transmission Fix" thick).
Label on bottle says it works in 200 miles or 3 days of driving.
Monday, I worked the "Luv" Machine heavily all day hauling load after load of brush, (limbs and branches) and even pulling heavy logs with a chain to one corner of propety and piling them there. Machine ran hot and fluid ran in a pretty constant stream from front seal. The only time I stopped working was for Lunch and Supper.
Tuesday morning, I added a quart of DEXIII/M fluid and a quart of 40 weight AND another bottle of "Bar's Leaks" Transmission Stop Leak Concentrate." Worked the "Luv Machine" in the same manner as Monday. Leak slowed to slow drip.
Wednesday morning. Added no fluid but worked all morning till 11:00 am. No leaks, no drips, no drops.
How long this will last I have no idea, but as of today, it is working. In these parts, "Bar's Leaks" Transmission Stop Leak Concentrate" is 4 bucks for an 11 oz bottle.
I also noticed the transmission has not only stopped leaking but is working much better than it has in a long time. Gears grab better, gears engage sooner, transmission pulls better, (very noticable when pulling heavy logs).
I rate this a success.
