Oil Condemnation Limits as established by Used Oil Analysis cannot be done within a narrow view, it has to be done with a macro or Global view.
http://www.reliabilityweb.com/excerpts/excerpts/getting_the_most.pdf
One oil analysis or snapshot says nothing. This is something we have a hard time getting across to people here on this board and elsewhere.
They get a Used oil analysis, commonly called a UOA, and want people here on the board to analyze what is going on and give them remediation comments. This is not the proper way to do oil analysis.
When doing oil analysis and establishing limits, you have to do what is known as "Trending."
First off, this means taking a sample of the fresh or new
oil currently being used in order to compare it against the UOA when it arrives.
Using the same oil, you then run a specified interval and sample.
You have to do this at least three times with three results, with the same oil, and look for trends or changes, called Deltas.
For example, is the iron level going trending downward after a FF drain? Good.
Stating or applying a single rule of thumb to oil analysis generates a false signal without knowing what would cause say viscosity reduction or viscosity increase.
As an example, let's say we see a trending, not just one analysis snapshot, toward a reduction in viscosity.
In order to make sense of it, we need to look at the root cause or what factors could cause it. Is the oil shearing down because of?
1. Oil formulation (unlikely)
2. Fuel dilution (possible)
3. Racing causing undue stress on an oil too low in viscosity or an oil having a low HTHS?
IN other cases, a condemnation limit for TBN might be set to 1.0 or a percentage drop in tbn over a specified interval. Or for diesel oils, a condemnation limit might be set for a certain soot level, depending on the manufacturers literature.
So the bottom line is, you have to consider a number of factors using trending, driving habits, environmental conditions, etc wrt establishing limits.
What applies to one engine may not apply to another engine.
