Heres the 1st UOA on our 2013 Equinox with the 3.6L V6.
My 1st venture into a synthetic oil. Ive always run Valvoline 5W-30 dino oil in my 2010 Traverse with the 3.6.
But due to Dexos--- I decided to use PP. Its cheaper to get PP on sale- than to buy Pennzoil Semi Syn in the quart bottles.
Im curious to see how accurate the OLM is on this engine. My goal is to use oil to the point that its not being drained too early.
1st oil change on this vehicle was at 1,510 miles.
Refilled with Pennzoil Platinum 5W-30.
For this UOA- engine had 6,178 miles. The oil had 4,607 miles. OLM was at 28% life.
Based on that.. I was getting about 63.9 miles per 1% OLM drop.
It appears that next time I should be able to go 6,398 miles as per the OLM hitting 0%
Im thinking of draining the next oil at 5500? 6000? and getting another UOA.
This 2013 takes 6 quarts with filter.
I drained out about 5.9 quarts.
Filled the 5 qt bottle.
then trasnferred 1 qt to the other jug- then refilled.
You can see where I marked the bottle at the quart lines.
