Hi all,
This is my first UOA on my 1997 Valmet 365 farm tractor with SISU 320D 3 cyl engine, bought at 2600 H.
The engine has now 2820 H, and the oil had 118 H and 2 years when changed.
This tractor always run idle or under light load (except 20 Hours by year), whith a lot of start/stop
Oil is an european Q8 1000D 10w30 STOU
Initial TBN is 10 (factory data, no VOA for it)
Oil: 118H/2 years
There is some little diesel in oil, but should be normal as running often idle.
I have no universal values, but the lead seems high for 118H, and the TBN fell down from 10 to 2.3.
For me, it indicates a acid corrosion. Do you agree ?
Despite the low number of hours, this oil cannot be kept more than one year. Low quality TBN additives or fuel dilution problem ?
Do you think I could keep a better oil 2 years in the sump ? Or should I definitivly change any oil every year despite the low hours ?
Oil: 118H/2 years
