So, the next thing on the list for my 88 GMC Suburban is getting the 4 power windows working. I replaced the fuses because that was a cheap possible way to fix their operation.
Unfortunately that wasn't the problem.
They are all stuck in the up position and don't move when I use the window up/down buttons on any of the doors. The front passenger window is stuck mostly up(it's down about an inch). Currently it is taped to prevent rain from getting in.
I'm thinking I need to replace the window motors. I've done some research and it seems fairly easy. I'm wondering though if there is anything special I should know that I may not have learned yet? I know I'll need to drill out the rivets. One thing that has me concerned is I sometimes read about a spring that can do some damage if not held/bolted correctly. Not everything I read mentions this though so I am concerned whether this will be a problem and if so how do I prevent/minimize the issue?
Also, do the windows need to be up or down when I replace the motor? I've read mixed things about this as well.
Another thing is my tailgate window will go up and down if I use the key in the tailgate but the button upfront won't operate it. I assume this means the button is bad? Is that an easy replacement?
Thanks.
Thanks.
