Originally Posted By: Quest
not sure if what I'm seeing is a magnetic plug, but the creamy milky part seems like there's moisture in the oil (water or coolant)?
I'd drain it if I were you...better yet: see if you can send the oil to blackstone or similar to see if you have a gasket related coolant leak?
Yes, it's a magnetic plug, and regarding the milky colored substance... my first thought was moisture too, but it's isolated to the magnetic plug i.e. the rest of the oil looked "normal". Also... the oil was drained... kinda hard to keep it in with the drain plug on my workbench.
Originally Posted By: 147_Grain
Change the oil and filter.
Are you doing a lot of short trips where the engine doesn't reach operating temperature for 30 minutes or more to burn-off contaminants and etc...?
If so, more frequent LOF maintenance is likely needed.
Yes, I do a considerable amount of short trips. LOF is what exactly?
