Thx so much for your sharing, JimPghPA! Excellent advice.
@oilboy: the 120000series B&S is (if memory serves), those darm B&S 675 series that the autochoked carb tends to be a pain..
clean the carb well, install a 150 micron mesh fuel filter (see my posting on the fix RE: 127K model B&S 675 series on the Ethanol posting (I fixed last year).
If you are careful enough, undo the walbro carb fuel bowl's screw and drain the bowl (after you installed fuel filter). See if you can detect some moisture and debris mixed in the fuel. Drain it well, rinse it with carb cleaner and then wipe it dry and clean with lint-free paper towel...
Re-install and then try again.
If hard starting happens when hot, listen to the carb (intake part) with air-filter off while pulling the rope....if you hear slight popping sound from intake, then the engine is suffering from more or less the same issues like I've been solving for my friends....gummed up intake valve seats, which altered the valve lash clearances on the engine...the only way to resolve this is to get a full B&S overhaul kit (with cyl head gasket, valve chamber retangular gasket, etc. pull off the cylinder head, undo the side chamber (you must undo the muffler first in order to access the valve chamber behind it) where the valves can be accessed...undo the valves (with special B&S small engine tool, avail on ePrey) and then clean the valves, lap the valves to their seats, and then re-install them and check for proper valve lash clearances (for 12xK series, intake and exhaust are between 4thou and 5thou).
While you are at it: decarbon both the combustion chamber and the piston head before reinstalling the cyl head...
That should fix these headache-y B&S autochokes...
Good luck.
Q.
You can reference to my last year's like RE: primer bulb'ed B&S675 cylinder head servicing and valve service:
http://www.bobistheoilguy.com/forums/ubb...444#Post2664444
