Originally Posted By: Quest
what car, what mileage, what mechanical conditions, etc?
Car is 110,000 Dodge Neon 2000. At 105,000 put in M1 HM oil and Napa Platinum filter. The car ran on nothing but Valvoline White Bottles and a case or two of Castrol GTX. Think the problem, when I notice it, started about in the low 80Ks with the low oil warning light coming on twice. Drained and replaced what little black oil it had in it with Valvoline SynPower 10w-30 + Fram ToughGuard at 83,200.
Added a quart (used up the oldest oils which was 12-pack Valvoline Racing 20w-50 then a 6 pack of Durablend, then what ever Dino I had left in my stash) every time it needed it.
Every 30K I add a bottle of STP Complete Fuel Cleaner to the gas tank. New PCV, lower radiator hose, serpentine belt, water pump, transmission fluid, coolant fluid, break fluid, steering fluid Prestone plus stop leak, Thermostat, All 4 coil springs n structs n shocks, and Key ignition solenoid.
Originally Posted By: Clevy
It could be that the rings are coked up.
Very likely.
Originally Posted By: V8man
Piston Soak!
I will do that soon with Mopar Combustion Chamber Cleaner than replace the original spark plugs and motor oil-filter.
What is left to be replaced: Cabin air filter, timing belt, the radio, and the starter.
