I have an extra pail of Shell Spirax S4 TXM, its GL-4 and SAE J 306 85W rated.
Any reason I can't use it in the manual trans and transfer case in my Tracker? I wonder if the wet brake anti chatter additives would not allow the synchros to work properly?
GL-4 75W85 is allowed for all operating temperatures in the manual and the spirax has a pour point of -42 so it should be OK for cold weather atleast.
The diffs are spec'd for GL-5 hypoid gear oil so I'd assume they would wear quickly with a GL-4 oil.
I'd think someone has tried this before as tractor fluid is about half the cost of a 75W90 gear oil.
