I need to rotate the tires on my car, an Acura TL with Sh-Awd, which has about 11000 on it. All of the rims are in their original factory positions.
The question is how do I go about doing this myself. The factory Michelins are directional, I believe, and I want to go front to rear and vice versa. If I jack up the rear of the car in the center, I can put jack stands under the two rear jacking points, under the rear doors, but then what? Do I jack up the front? Do I need four wheel stands? Is it safe to jack the front when the car is sitting on two jack stands?
An alternate method would be to use the factory spare, which is a donut, take off one tire at a time. Question is if the donut's diameter is considerably smaller than the factory rims, which are 18 inchers with 45 profile tires, can I safely jack up the car when there is a donut on the other end, or will the car be too low to jack high enough to get the standard rim off?
I realize I could just pay a tire place to do this for $30 but then I have to worry that they will overtorque the lug nuts.
Any suggestions for a plan of action?
