Industrial hand cleaners?
by KenO
07/26/16 11:58 PM
Shell Rotella T6 in a Altima 2.5
by Grambo
07/26/16 11:24 PM
"Creaking" Conti DWS's?
by Lolvoguy
07/26/16 10:52 PM
Check your car after it's been worked on
by Nick1994
07/26/16 10:15 PM
How are lg android devices now days?
by ram_man
07/26/16 09:42 PM
Dexos 5w30 with highest 100°c Viscosity
by CapitalTruck
07/26/16 09:32 PM
How do you avoid being perceived as a rookie when
by motor_oil_madman
07/26/16 09:27 PM
Oil opinions after dumping FF
by JoelB
07/26/16 09:27 PM
Bulk loading a grease gun?
by buck91
07/26/16 08:59 PM
Sears Battery Pricing
by PeterGreen
07/26/16 08:29 PM
My 12am emergency strut spring repair on a Civic
by Colt45ws
07/26/16 08:19 PM
My upper sidewall pinehole leak fix
by Pokermatters
07/26/16 07:52 PM
snydercn, surfbum, Tmemz4, woollum86, Phil108
58612 Registered Users
27 registered (Charlie1935, ChristianReske, 182RG, Bottom_Feeder, CrazeeDad, 2 invisible), 834 Guests and 14 Spiders online.
58612 Members
66 Forums
252296 Topics
Page 2 of 2 < 1 2
#2965854 - 04/08/13 05:55 AM Re: Pablo, are Amsoil oil filters stillthe best? [Re: fpracha]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Originally Posted By: fpracha
Hi Pablo!
Exactly why did the previous Amsoil filters for "certain Honda/Toyota" ... "became too restrictive during extended drains. ..."
At what intervals will these previous Amsoil filters still not become "too restrictive" ?
In closing, even if the Amsoil filter has become too restrictive, will it start releasing "previously trapped dirt etc." into the engine OR will it just affect fuel economy (after the filter has become too restrictive) ?
Why? The media filled up as stated.
When? I think 15K-25K miles. But even then, it was quite rare.
I think it would have gone into bypass at some point.
#2966207 - 04/08/13 12:46 PM Re: Pablo, are Amsoil oil filters stillthe best? [Re: Pablo]
OVERKILL Offline
Loc: Ontario, Canada
Originally Posted By: Pablo
Originally Posted By: Clevy
Originally Posted By: motor_oil_madman
i wonder what they chnged cause i have three amsoil filters that say 98.7% at 15 microns
Likely changed once someone else started making them.
I think its a step in the wrong direction not having wix make all their filters. Looks like napa golds for me.
The change from Wix had nothing to do with the media. Wix never made all the filters anyway. Napa gold filters are fine, but they don't have the same Donaldson media that the Amsoil filters use.
^This.
I'd take Donaldson over WIX any day wink
02 Expedition
06 Charger R/T
14 Charger SRT-8
#2967420 - 04/09/13 03:26 PM Re: Pablo, are Amsoil oil filters stillthe best? [Re: OVERKILL]
asharris7 Offline
Loc: Greensboro NC, USA
Pablo,
What are your thoughts on the NAPA Platinum?
2015 Volkswagen Passat TDI (company car/free oil changes)
2011 Honda Odyssey
Right now: PP 0W-20(Fram Ultra)
Amsoil ATL in the Trans
#2967575 - 04/09/13 06:01 PM Re: Pablo, are Amsoil oil filters stillthe best? [Re: asharris7]
Pablo Offline
Originally Posted By: asharris7
Pablo,
Never used one, little knowledge. I assume made my WIX.
#2967647 - 04/09/13 07:05 PM Re: Pablo, are Amsoil oil filters stillthe best? [Re: Pablo]
asharris7 Offline
2011 Honda Odyssey
#3002144 - 05/14/13 05:52 PM Re: Pablo, are Amsoil oil filters stillthe best? [Re: Pablo]
brakebleeder Offline
Loc: Utah
Are Fram filters anygood? That's all I have used except for some STP.
#3003914 - 05/16/13 11:18 AM Re: Pablo, are Amsoil oil filters stillthe best? [Re: brakebleeder]
StevieBoy Offline
Loc: Central Florida
The only Fram I would use is the Ultra. I think the STP filter is a cheap imitation of what one would expect of the STP brand. Unfortunately Amsoil doesn't make a filter for my 4.0; I do like what I see of the NAPA Platinum. I'll probably start using them rather than the P1 for longer OCI's.
2016 Grand Cherokee Laredo
75th Anniversary Edition
#3023682 - 06/05/13 01:10 PM Re: Pablo, are Amsoil oil filters stillthe best? [Re: sprintman]
Pajero Offline
Loc: Rio Rancho, NM
There gear oil and ATF fluid are top notch. So is there motor oil....
#3076493 - 07/25/13 09:45 PM Re: Pablo, are Amsoil oil filters stillthe best? [Re: Pajero]
NYSteve Offline
Loc: Killadelphia
Here is the link to the TSB:
http://www.amsoil.com/techservicesbulletin/filtration/tsb%20fl-2009-05-01%20eao%20toyota.pdf
ISSUES:
A small number of customers with Toyota, Lexus and Pontiac vehicles with Toyota-built engines have reported that
their vehicles’ oil pressure light has illuminated prior to
reaching the end of the AMSOIL-recommended 25,000-
mile drain interval.
RECOMMENDATION:
AMSOIL no longer recommends EaO09, EaO10 or EaO57
Filters with any Toyota/Lexus application, or with the Pontiac Vibe featuring the 1.8L or 2.4L engines built by Toyota.
For customers operating any of the above listed applications, AMSOIL offers MANN Filters as an alternative to
the Ea Filtration line. MANN Filters can be used for up to
7,500 miles when used in conjunction with AMSOIL synthetic motor oil.
#3080777 - 07/30/13 12:00 PM Re: Pablo, are Amsoil oil filters stillthe best? [Re: sprintman]
WoodenNickle Offline
Loc: N.E. OH
Regarding filtration, here's something to think about. There are two ways to rate the removal rate of the filter media: nominal or absolute. Most all filter manufacturers use the nominal rating. In other words, nominal ratings mean a filter will remove less than 100% of the dirt that it's challenged with. I'd much rather have a absolute rating, meaning 100% removal, even if the micron size goes up. That way, you know the size of the biggest particle getting through the filter. With a nominal rating, if it's 90% of the dirt challenge, there's the unknown 10% that's going to be bigger than the published particle size. Also, the nominal percentage may be 80%, 70% or some other number.
When I asked Amsoil what the absolute rating of their filters were, I got a straight answer. Most people don't realize that almost all of the filter manufacturers are, in effect "cheating" by making it look like they make a superior product.
I know Amsoil has a superior product, because I asked and got an honest answer!
Regards,
WoodenNickle
#3080832 - 07/30/13 01:01 PM Re: Pablo, are Amsoil oil filters stillthe best? [Re: brakebleeder]
Clevy Offline
Loc: Saskatoon canada
Fram has tiered filters. The orange can is their lowest tier. It's acceptable however for the price a purolator can be found cheaper for the same tiered filter.
So fram makes 3 tiers= minimum,acceptable,premium.
Their premium filter called ultra is a very good filter and when compared to other brands in its class it can be bought cheaper,which makes it a good value. In order to get your money's worth out of a premium class filter you need to run an extended drain of 15000 miles.
I run the basic filters for 10000 miles,which,depending on whether there was elevated idling or whatever that could be one or 2 oil changes before I change the filter.
On an engine that's clean inside a basic filter should be in service for 10000 miles,unless the engine is very dirty.
2006 Charger RT
Miles x 2 per oil filter
#3561693 - 12/10/14 05:15 PM Re: Pablo, are Amsoil oil filters stillthe best? [Re: sprintman]
benjy Offline
Loc: pa
does the fram ultra filters use ultra cardboard end caps? fram is highly advertised cheap junk IMO. i have used Amsoil for years + have always changed the oil filter at 6 mo on a yearly change, cheap insurance for sure
#3578760 - 12/26/14 10:14 PM Re: Pablo, are Amsoil oil filters stillthe best? [Re: benjy]
Garak Online   content
Loc: Regina, Saskatchewan, Canada
There are many threads with many pictures detailing the construction of the Fram Ultra filter in the filter subsection.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
Page 2 of 2 < 1 2
