Highway conditions in the Midwest
by grampi
07/01/16 08:22 AM
Indian head shellac or something?
by JHZR2
07/01/16 08:15 AM
Need Help! Tombstone
by AirgunSavant
07/01/16 07:38 AM
Truck bedliner - pros and cons and option
by ryan2022
07/01/16 07:33 AM
Delo 400 SD 15w30 From Amazon
by AirgunSavant
07/01/16 07:27 AM
GM LS 6.0 Suggestion
by akcooper9
07/01/16 06:58 AM
Penrite 5W-30 Full Synthetic
by KL31
07/01/16 06:08 AM
PP HM at Walmart
by dlundblad
07/01/16 04:55 AM
74/76mm x 15 Flutes
by Merkava_4
07/01/16 04:33 AM
Autozone - Pennzoil with the PP - Rebates
by Kwuality
07/01/16 03:29 AM
Old Toyota
by artbuc
07/01/16 03:18 AM
Shell Helix Ultra 5W-20 & 0W-20 in Australia
by SR5
07/01/16 03:03 AM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
84 registered (ac_tc, ARCOgraphite, badtlc, AirgunSavant, b1amgm47, AEHaas, 5 invisible), 1594 Guests and 12 Spiders online.
58332 Members
66 Forums
251084 Topics
Page 1 of 2 1 2 >
#2955036 - 03/29/13 03:43 AM Oil for Mercedes Slk 230 Kompressor
Giorgiz Offline
Loc: Italy
Hello everyone, I would like some advice on a good oil to use in my kompressor, currently use the Shell Helix Ultra 5W40 is said to be an excellent oil, but I would like to move on to something less viscous type 0W30, risk of doing damage with this viscosity? The use of my car is mostly over short distances of about 15-25 km, normal driving with light foot between 1500 and 2500 rpm, some pulled up to 5000 rpm, operating temperatures from 0 to 40 Winter Summer I live in the south of Italy. I took a look at several good oils: Amsoil Signature 0W30, 0W30 Redline, Mobil 1 AFE 0W30, Pennzoil 5w30 ... I'm really confused, I accept the advice of any kind.
#2955076 - 03/29/13 06:07 AM Re: Oil for Mercedes Slk 230 Kompressor [Re: Giorgiz]
05LGTLtd Offline
Loc: Va
Is castrol 0w-30 available to you? (MB 229.5)
Have you considered 0w-40's?
Shell helix is a very good choice for you, imho. Don't think you will gain much by switching to to 0w-30 at your location. If it makes you feel better as long as it carries your MB spec it certainly won't hurt anything though. What's your MB spec?
2005 Legacy GT, Synpower 5w-40
2010 Forester SOHC, Edge 0w-30
#2955126 - 03/29/13 07:01 AM Re: Oil for Mercedes Slk 230 Kompressor [Re: Giorgiz]
Quattro Pete Offline
Loc: Great Lakes
If I remember correctly, your engine calls for an oil meeting the MB 229.5 spec. And if so, none of the oils you mentioned above meet this spec. They couldn't meet this spec because their HT/HS is below 3.5 cP, among other things.
I would just stick with Helix Ultra 5w-40 that you're currently using. If not, M1 0w-40 would also work, or any other oil meeting MB 229.5 spec.
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#2955133 - 03/29/13 07:05 AM Re: Oil for Mercedes Slk 230 Kompressor [Re: Giorgiz]
bigjl Offline
Loc: London, England
Personally I would use Mobil 1 New Life 0w40.
No point in over thinking it.
You could also consider Castrol Edge 0w40 or a cheaper alternative would be 10w40 Castrol Magnatec (A3, B4).
I think it will come down to what is widely available and I have never been to Italy so don't know what is easy to find.
I would not drop down to a 0w30 or 5w30 myself especially if you like to enjoy the power regularly.
You will find that some of the opinion on the site can be more relevant to the US based driver and whilst given in good faith and well thought out I suspect UK usage is probably closer to your usage.
Especially as you have a supercharger to look after.
A 0w30 or 5w30 would likely be fine but is fine good enough for you?
Here is a list of alternative viscosities from the European Castrol site which was pretty much the same as that published by Mobil.
"Alternative recommendations: -25C to >30C, 0W-30; -25C to >30C, 5W-30; -25C to >30C, 5W-40; -25C to >30C, 5W-50; -20C to >30C, 10W-30; -20C to >30C, 10W-40; -20C to >30C, 10W-50; -15C to >50C, 15W-40; -15C to >50C, 15W-50"
This shows that the engine can take a lot of different viscosities as long as they meet the MB spec.
Got to be Mobil 1 0w40 for me though.
Though your current choice is not a bad one by any means.
And if it is working for you why change what works!
Edited by bigjl (03/29/13 07:07 AM)
14 Kia Picanto 1.0 City 10k miles. Kia 5w30
07 Citroen Berlingo Multispace 1.4i 39k 10w40 Maxlife
#2955318 - 03/29/13 09:53 AM Re: Oil for Mercedes Slk 230 Kompressor [Re: Giorgiz]
Giorgiz Offline
Loc: Italy
in truth I'm not going to look very specific mb, as my engine, as it was produced in 2000, are "satisfied" the old specification 229.1 mb, therefore all subsequent 229.3, 229.5 are fine. 0W30 oils I mentioned, the only one with specific mb 229.5 is the redline, but I think it's a discourse of trade agreements, I do not think that putting AMSOIL 0W30 HTHS of 3.1 instead of 3.2 as redline you can do so much harm to the engine. Mobil 0W40 I immediately discarded because it is more viscous than the shell that I currently also have a lower cleaning power of the shell, castrol in my part does not have a good reputation, then forgo, I would try to put a good 0W30 oil that has excellent cleaning power, since my engine has almost 170,000 km, no one can tell me of AMSOIL, redline, Mobil1 or afe which is better? I repeat that among these 3 oils, the only one with a specific 229.5 mb is the redline 0w 30.
#2955353 - 03/29/13 10:34 AM Re: Oil for Mercedes Slk 230 Kompressor [Re: Giorgiz]
Clevy Offline
Loc: Saskatoon canada
If I could afford it I would use red line fluids exclusively. That being said their motor oils seem to be hit and miss as far as extended drains are concerned.
So I would use the red line option at 8000km intervals.
However likely the best oil for your application is the euro M1 0w-40. I don't quite understand why you think it's too thick but that's your call. The AFE will be thinner and is a very good product as is amsoil.
Amsoil can likely go longer in the sump as well. Why not try each one and do a uoa and determine an interval based on the data you glean. Likely smarter than just guessing and since you are using a thinner than recommended oil it might be smart to see how they do and see how the wear metals end up.
Keep us updated. We love data and experiences. Especially when you are trying something that isn't quite what the manufacturer suggests.
2006 Charger RT
Miles x 2 per oil filter
#2955355 - 03/29/13 10:35 AM Re: Oil for Mercedes Slk 230 Kompressor [Re: bigjl]
FoxS Offline
Loc: CA
This post is very misleading
The US posters advised him to use MB spec oils. MB are consistent around the world with their oil specs. They also have many engines in the US that are also sold in Europe. Right now they have turbos and twin turbos in the US that definitely need more robust oil, the same oil recommended in Europe.
There is simply no basis for saying US posters familiar with MB requirements are going to give the wrong advice.
Indeed, you went by SAE viscosity which is not how MB spec their oil. They generally allow 30 or 40 weight oils that meet a myriad of tests under their 229.5 spec including a min HTHSV of 3.5.
By saying Magnatec 10w40 is suitable, based on a UK bias and because it is a 40 weight, completely ignores that it does not meet MB229.5 spec.
Similarly, discounting 30 weight oils because they are 30 weight oils discounts 30 weight oils that meet MB specs.
And then lastly listing alternative viscosities rather than the MB sheet is the final piece of useless information as it implies a wide range of oils are suitable when they are not.
So it is the UK poster who is giving the wrong advice, in no small part due to a characteristic lack of rigor / attention to detail.
OP, don't listen to this poster. Find the right spec sheet and then compare the TDS / PDS of oils on there that you can buy in Italy. To some extent ignore the slightly higher HTHSV of oils like M1 0w40 and compare the VI. M1 0w40 has a much higher VI than Castrol.
Having said that, truly approved oils (Redline isn't approved I believe) meet really high performance characteristics including cleaning and starting viscosities. You can't go wrong with any approved oil, and M1 0w40 is widely considered the best due to its technical characteristics and excellent test results.
#2955500 - 03/29/13 12:40 PM Re: Oil for Mercedes Slk 230 Kompressor [Re: Giorgiz]
Giorgiz Offline
Loc: Italy
redline 0W30 is approved 229.5 mb so this oil is definitely good for my mercedes, I would like to know what advantages and disadvantages do I get with the redline compared to mobil 1 0W40 recommended by you.
#2955502 - 03/29/13 12:42 PM Re: Oil for Mercedes Slk 230 Kompressor [Re: Giorgiz]
OVERKILL Offline
Loc: Ontario, Canada
Redline is NOT an approved oil for this application. It is RECOMMENDED FOR. COMPLETELY DIFFERENT.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#2955503 - 03/29/13 12:42 PM Re: Oil for Mercedes Slk 230 Kompressor [Re: Giorgiz]
Loc: Great Lakes
Then just pick an oil from this list and call it a day:
http://bevo.mercedes-benz.com/bevolisten/229.1_de.html
Personally though, I would be looking at an oil that also meets 229.5 as it is a more stringent spec and therefore assures you get a better oil.
I know that Redline's website says "Suitable for VW/Audi 503.00 and 503.01, as well as Mercedes Benz 229.3 and 229.5" but I really think it's very misleading. Their 0w-30 has HT/HS of 3.2 cP and therefore could never possibly meet those MB specs.
Are you worried that a higher viscosity spread will result in less shear-stable oil? I think you're worried about the wrong things, to be honest. Slight shearing is not a problem. The problem would be not having enough film strength at high stress high temp conditions which your engine may encounter. The MB spec assures that by specifying the minimum HT/HS.
But if you really want an oil with the smallest viscosity spread and that still meets MB spec, just pick any of the 5w-30 oils on this list:
http://bevo.mercedes-benz.com/bevolisten/229.5_de.html
#2955508 - 03/29/13 12:44 PM Re: Oil for Mercedes Slk 230 Kompressor [Re: Giorgiz]
OVERKILL Offline
FWIW, Mobil's oil recommendation tool yields that their 0w-40 is the appropriate lubricant for this application.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#2955517 - 03/29/13 12:52 PM Re: Oil for Mercedes Slk 230 Kompressor [Re: OVERKILL]
Giorgiz Offline
Loc: Italy
[quote=Giorgiz]
redline on the site is written clearly 229.3 and 229.5 mb http://www.redlineoil.com/product.aspx?pid=125&pcid=21
#2955521 - 03/29/13 12:59 PM Re: Oil for Mercedes Slk 230 Kompressor [Re: Giorgiz]
FoxS Offline
Loc: CA
Lol the Brits go by Castrol's website and the Italians use Redline.
MB are one of the few manufacturers to provide a comprehensive list of approved oils. Why not go by that?
#2955542 - 03/29/13 01:27 PM Re: Oil for Mercedes Slk 230 Kompressor [Re: Giorgiz]
Loc: Great Lakes
[quote=Giorgiz]
Giorgiz, we know what it says. The devil is in the details. It is not officially approved by MB. Redline only says "suitable for", which is not the same as "approved". As I mentioned before, one of the key requirements of the MB spec is that HT/HS has to be at least 3.5 cP. Therefore, this Redline oil could never pass the MB spec test. Personally, i wouldn't even consider it "suitable", but Redline seems to think otherwise for some reason.
Anyway, you don't have to follow our advice if you don't want to. We really don't care what you put in your engine because it is not our engine. smile
#2955572 - 03/29/13 01:54 PM Re: Oil for Mercedes Slk 230 Kompressor [Re: Giorgiz]
OVERKILL Offline
[quote=Giorgiz]
No, it doesn't.
It says:
Which means they RECOMMEND that particular product for engines that require those specs. It does not, in ANY WAY mean that the product is officially sanctioned by Mercedes for use in their engines, which it isn't.
02 Expedition
06 Charger R/T
14 Charger SRT-8
Page 1 of 2 1 2 >
