Originally Posted By: Clevy
Try the mmo. It's cheap. Add it a couple hundred miles before you plan on changing the oil and if it helps then great,if not,keep looking but for what it costs to try why not give it a shot.
Thanks for the feedback. I'm going to give demarpaint's suggestion w/the serpentine belt a shot, and if the noise is still there w/the belt off I will try the MMO. Would you do a quart or just a pint? The oil capacity is 4L.
