Originally Posted By: CapriRacer
Just an FYI:
What they showed of making a tire was hand built prototype level stuff - not the highly mechanized stuff used in normal manufacturing.
It was clear there were trying to hide the stuff they think is secret. What they taped didn't tell me - someone very familiar with tires - with any hint of how they actually do it.
That was what got me thinking right away. I have been in tires before but never really got into figuring out how they made all of them. The few programs I saw here or there were vague as well. I saw that guy building a tire and said to myself "if they all get built at that rate, I can see the price", but I figured there had to be more. That guy was in his own little area with nothing around. Seemed laid out oddly for a production setting.
I guess if you think about it, the program was not about tires, it was showcasing Michelin. If it was intended to show how a tire is made then I would expect more, but it did what it was supposed to.
I still feel I have no idea of how a tire is actually put together start to finish and why everything works the way it does. It's been bothering me now since I watched that video.
Michelin seems to be on the cutting edge for a lot of things. Not all of them work, but they are not afraid of innovation. Their IF/VF tires for Ag have changed the industry.
Originally Posted By: Hokiefyd
I'm interested in the water-channeling tires on trucks, and if that technology can be applied to passenger car and light truck tires as well.
Yes, it can.
This is all about the compromise. Obviously a truck tire using 100 psi (or so) would have a different set of compromises than a passenger car tire at 35 psi (or so) does, but the principles are the same.
Compromise is always there unfortuneatly. You can go for low spray and a fuel efficient tire, but suffer off road traction. Go for off-road traction and you generally get some bad spray. The tires below are Michelin X-Works XDY's that I put on one of our trucks. In the rain they shoot water worse than any tire I've seen but I think a lot of it has to do with the cupped tread. Maybe. I notice it launches a lot of water straight over across the lane and not as much in a big "bubble". Just put them on in November. Lots of mud forming around here now, can't wait to finally test the mud traction.
