Originally Posted By: 440Magnum
I've gotten VERY curious about Ultra since buying my Challenger SRT-8. I've been using M1 0w40 for a while in other vehicles (including my vintage big-blocks) and there's enough info out there in the form of VOAs and UOAs plus data sheets to conclude that its a great oil (maybe one of the best on the mass market.) PU 0w40 was allegedly designed specifically for the SRT vehicles, "co-engineered" with Chrysler engineers if you believe the advertizing, and the other grades show things like the great NOACK and apparent shear resistance. Hence it looks like THE oil for that car. Problem is, specific info on PU in the 0w40 grade (and the 0w40 oil itself, for that matter) is scarce as hen's teeth. On the Challenger forums, there's a fair amount of griping that Chrysler dealers are still using 5w40 when people take SRTs in for oil changes in many cases. If PU is as good in 0w40 as it is in other grades, and if its 0w40 has as strong an anti-wear package as M1 0w40 does then it might be what I go with in the future- especially for the SRT-8's 392. But I'd sure like to know for sure, and I sure as HECK won't use it in the 440s unless it shows >1000 PPM ZN/P like M1 does.
I've used the search engine until my hair is falling out with no success- do any of y'all know of a PU 0w40 VOA or UOA on here?
You are correct there's not a lot of information regarding the 0w40 flavor of PU. I haven't even seen any UOA/VOA's of the 0w40, Euro 5w40, Euro 5w30, and the Ferrari 10w60.
If you're up for giving it a shot then you'll be the first to have any real info on the 0w40 weight. I'm pretty sure they of high quality as they are within the same PU product line.
There's also nothing wrong with just sticking with M1 if it's working out well for you.
