Motorkote ??
by Moondawg
07/29/16 08:53 AM
Windows 10 For Free Last Day
by NHHEMI
07/29/16 08:24 AM
HD Truck Maintenance Costs - Wow!
by Miller88
07/29/16 08:10 AM
1,000,000 mile Tundra
by Hokiefyd
07/29/16 07:34 AM
Choosing oil with both CJ4 and SN specs
by devarshi84
07/29/16 07:11 AM
Stapled down carpets ???
by Oldtom
07/29/16 01:51 AM
MicroGard (Wix) 57047 ~7k miles
by MrQuackers
07/29/16 01:24 AM
Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
07/29/16 12:50 AM
Only secure content is displayed?
by Eddie
07/28/16 11:35 PM
2008 Honda Element oil question
by fujirio
07/28/16 09:50 PM
TIRE QUESTION
by renegade_987
07/28/16 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
07/28/16 09:30 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
75 registered (09_GXP, 911Don, 2009Edge, 87sammy, 2010Civic, 2002 Maxima SE, 6 invisible), 1779 Guests and 11 Spiders online.
58632 Members
66 Forums
252390 Topics
#2874257 - 01/17/13 01:52 PM Ford Focus rear brake drum won't come off
tinmanSC Offline
Loc: Oswego, IL
This is actually the second time on BITOG i've asked for help in removing something related to brakes, this time it's the rear drum on a 2000 Ford Focus SE. It has a 30mm bolt that holds it on, which is part of the bearing, I suppose. I took that off, came off ok, but the drum will only move about 1/4 of an inch. It doesn't seem to have a retractor on the back. I've pounded on this thing forever, and it doesn't want to come off. Any advice on removing stuck rear brake drums?
Also, in this case, there is no little hole on the drum to put a bolt through, and the wheel studs are part of the drum.
Cost of Hobby=2L
(Where L=Cost of Lubricant)
95 Lexus SC300 [email protected], 2000 [email protected] both VML Full Syn+Purolator PSL20195(soon to be Wix)
#2874266 - 01/17/13 02:00 PM Re: Ford Focus rear brake drum won't come off [Re: tinmanSC]
Donald Online   content
Loc: Upstate NY
Does it have a rubber plug on the backing plate you can remove and stick in a thin screwdriver and a brake adjusting tool?
That is the way you would "un-adjust" drum brakes to get the drum off on drum brakes I have worked on.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2874268 - 01/17/13 02:01 PM Re: Ford Focus rear brake drum won't come off [Re: tinmanSC]
driver123 Offline
Loc: cincinnati, ohio
On a Chevrolet you disconnect the E Brake , and the shoes should contract enough to remove the drum, not sure about Ford though.
2004 Audi A4 3.0 Cabriolet 0W-30 German Castrol Bosch Distance +
2002 Chevrolet Malibu 3.1 pennzoil Ultra 5w-30 W/ Fram ultra 121800 miles
#2874269 - 01/17/13 02:02 PM Re: Ford Focus rear brake drum won't come off [Re: tinmanSC]
randomhero439 Offline
Loc: ohio
If you really cant get it off. Try opening the bleeder screw and rotating it, it should eventually come off. Then bleed that brake when your done.
'00 S2000: Amsoil 10w-40, Honda OEM PCX, 129k
'03 Accord V6-6MT: Edge 5w-20, Honda OEM, 243k
'10 Mercedes GLK: M1 0w-40, Mann, 63k
#2874297 - 01/17/13 02:29 PM Re: Ford Focus rear brake drum won't come off [Re: tinmanSC]
DrDusty86 Offline
Loc: TX
Is it rusted? My zx2 I just take a rubber mallet and wack one size of the drum and it is off.
#2874319 - 01/17/13 02:45 PM Re: Ford Focus rear brake drum won't come off [Re: tinmanSC]
Tegger Offline
Loc: Canada
Looks like you need a puller. Watch this YouTube video:
http://www.youtube.com/watch?v=opNA1kOpKdc&noredirect=1
2013 Toyota RAV4 - 55,000 miles - Toyota 0W-20, Toyota filter
#2874330 - 01/17/13 02:53 PM Re: Ford Focus rear brake drum won't come off [Re: Donald]
tinmanSC Offline
Loc: Oswego, IL
The only rubber plug is on the right side, as you are looking at it. This is on the passenger side, so it's toward the front of the car. I'm used to these plugs being on the top or the bottom. Also, none of the instructions I've found online say anything about retracting the shoes by removing the plug and clicking it back. frown
Cost of Hobby=2L
#2874333 - 01/17/13 02:54 PM Re: Ford Focus rear brake drum won't come off [Re: driver123]
tinmanSC Offline
Loc: Oswego, IL
E brake comes off from the inside, per the info I found online anyway.
Cost of Hobby=2L
#2874366 - 01/17/13 03:23 PM Re: Ford Focus rear brake drum won't come off [Re: tinmanSC]
eljefino Offline
Loc: ME
Your shoes are stuck on a ridge inside the drum. The 1/4" you're getting are the shoes moving on their hardware... the springs and "nails". Probably you're going to need to buy a new hardware kit. Find anything "different" on the backing plate, use the other side as a mirror image diagram if you can. Cut the nail heads off and it'll fall apart.
#2874404 - 01/17/13 04:14 PM Re: Ford Focus rear brake drum won't come off [Re: tinmanSC]
OB4x4 Offline
Loc: sc, usa
Make sure you have the E-brake disengaged. I've seen it happen more than once where someone will pound on a drum thats locked in place by the E-brake.
00 toyota tacoma 3rz 181,000 mi
m1 5w-30 (5-7k mi oci), mt90, m175w-90.
08 scion xb 2az 70k mi.
m15w-20 (5k mi oci), idemistsu tls-lv
#2874546 - 01/17/13 06:18 PM Re: Ford Focus rear brake drum won't come off [Re: tinmanSC]
KrisZ Offline
Loc: Toronto, Canada
What I did, since I did not have any special tools, was to rotate the drum and using a mallet hit the drum on just one side. Rotate about 90 degrees and hit the side of the drum. That basically started to wiggle the drum little by little. Once the shoes were exposed a bit I pushed on them with a screw driver to compress them as much as possible. It took about 15 minlutes and it did scratch up the shoes, but I was replacing them anyway.
2015 Dodge//Grand Caravan-FF dumped
2006 Mazda 3-135k miles
#2875597 - 01/18/13 03:52 PM Re: Ford Focus rear brake drum won't come off [Re: OB4x4]
tinmanSC Offline
Loc: Oswego, IL
This turned out to be a fantastic tip! I never set the e-brake, but in making 100% sure it was not set I found an issue with it. I pulled the e-brake (hand brake, by the gear selector) and it would not come up, it stopped after only a very short movement, not even to the first click. Seems there is a problem with it. Thanks for the tip.
Cost of Hobby=2L
#2875770 - 01/18/13 06:38 PM Re: Ford Focus rear brake drum won't come off [Re: tinmanSC]
JetStar Offline
Loc: Flatlands of Indiana
IIRC the factory service manual instructs you to remove the 4 bolts from the hub assy on the backing plate. According to this article, there was a recall of some sort. Pretty high torque required on the drum / bearing nut too 173'#.
http://wiki.answers.com/Q/How_do_you_remove_the_rear_drum_of_2000_ford_focus
My weakness is I love all motorcycles regardless of brand
2016 Suzuki DR650
2015 Road Glide
2007 Yamaha FZ1
1978 Suzuki GS1000 (now 1085)
#2947274 - 03/21/13 11:27 PM Re: Ford Focus rear brake drum won't come off [Re: tinmanSC]
tinmanSC Offline
Loc: Oswego, IL
Thanks to everyone who posted. It did turn out to be the e-brake. The cable had rusted and was pulling on it, keeping the shoes extended, which was probably why they wore out so quickly. I cut the e-brake cable and they popped right off. Now to replace the cable.
Cost of Hobby=2L
