I have a 99 SL2 Saturn with 216,000 miles. In early October had a noise/vibration. Replaced top motor mount (common problem) which did not resolve noise. Went to a exhaust shop. I am thinking flex pipe may be bad. They said it was good, but told me my other mounts were shot. Replaced the worn out torque struts and transmission mount. Resolved the vibration/noise. Fast forward to last few weeks. Temps dropped. Now it is sounding like belt chirped and making noise when cold. Eventually replaced tensioner, idler pulley, and belt. Switched power steering pump fluid to Mobil 1. Seemed to resolve that noise. Currently when I am parked outside when temps in 30's car sounds loud at start-up. I am not hearing this noise when parking in garage. It reminds me of few times I have had muffler leak. This car has a fairly new resonator and muffler. Everything from cat forward is original. To ensure I do not throw parts at things, I am thinking flex pipe when cold leaks. When car warms up sound goes away and it makes a better seal. When the exhaust system was tested the car was fully warmed up. Before taking it to shop I noticed carbon residue around flex pipe. They did weld leak at resonator. That is all they found bad exhaust wise....All the parts I replaced were a hodge podge of after market ones that may be producing non OEM performance. Thanks in advance!
