Anyone try this yet? I've seen it for sale at Autozone. The rislone FAQ sheet claims that its safe to use in winter weather. That's always
Quote:
Rislone Oil Treatment is a high-viscosity formula developed for older and higher mileage engines to increase oil film thickness, building a thicker oil cushion and increasing oil pressure in worn engines.
* Cushions and coats engine parts to reduce friction and wear by preventing metal-to-metal contact between moving parts giving your vehicle longer engine life.
* Increased oil pressure equals increased power and a quieter running engine.
* Improved high-performance formula performs better in both hot and cold weather.
* Works with all gasoline and diesel engines using conventional, high mileage and synthetic oil.
*Use on any 4, 6 and 8 cylinder Car, Truck, Van or SUV
