I have an oil fired furnace, 2 story house with baseboard heating.
The norm seems to be that the system is filled with 100% water from the cold water supply,
has the pressure regulator and check valve which drops it to 10-15 psi.
my question is, is there supposed to be any kind of additive in the system to prevent corrosion?
I ask because a few years ago the service guy noticed i had some problems with the system, forget what actually but one or both of the zones was drained, I remember he at least changed the temp gauge on the furnace, then filled and purged both zones and that was it.
i replaced the pressure relief valve earlier today on the furnace, since it was the lowest point i ended up having to drain everything. wondering if i should look into some sort of additive, I hate to ask at a plumbing supply because i know they will say yes with some product in one hand and their other outstretched waiting for my credit card.
