Originally Posted By: Rolla07
Im deciding between Pirelli Cintuato P7 with a 700-A-A with a Pirelli PZero Nero with a 400-AA-A. Clearly the Pirelli Pzero's have a better traction rating, but clearly the P7's will last much longer in terms of treadwear. Do you guys know if there is a significant difference between an A and AA in terms of traction? ... Also, what would you choose? (only between p7 and pzero nero A/S). Only reason im getting Pirelli's is due to a good discount im getting. thanks!
... Wet traction is what I am more concerned with moreso than tire life, although if traction is a negligable difference, id take the longer lasting tires!
You will have very poor wet traction whichever of those two tires you choose. As others have noted, the NHTSA test procedure for Traction tests only one thing, and that is wet braking. But the test is deeply flawed even for that specific factor, and it is a "cheat sheet" for the flaws of all-season tires. The tire under test is mounted on a trailer, not on a vehicle, and the trailer is towed on a level surface in a straight line; then a chuck is thrown into the trailer axle to LOCK the wheel that the tire is mounted on; then there is a mandatory "wait" of half a second before the decelerative force is measured.
Here is what the problem is, especially when testing all-season tires: what makes a tire an "all-season" tire is that the tread compound has been chemically designed so that -- unlike tires using unmodified tread rubber compounds -- the tread does not shed water. That modification was made so that the tire will ahdhere to -- have traction on -- snow, because, under the pressure of the car's weight, the snow melts to water at the molecular level (molecular melting is the same process that allows you to take fluffy snow and pack it into a snowball that will "stick together"). While that non-shedding of water works on snow, which can be packed, it has an adverse effect upon traction on just wet -- not snow-covered -- surfaces, because liquid water does not pack, but the molecules just slide over one another.
Now, the NHTSA test procedure, by locking the wheel, ensures that only the one small patch of the tire -- the contact patch -- stays at the bottom of the tire's rotation for the entire measurement period, and does not rotate away. Moreover, the required "wait" ensures that the water that was on the contact patch will be scrubbed away before the measurement will begin. So the problem with wet braking that all-season tires have -- the water-to-water interface working as a lubricant -- is completely masked by the testing procedure.
Note that ABS exacerbates the issue, as what ABS does is precisely release the brakes upon detecting incipient wheel lock-up. So when, in real-life, not the test procedure, an all-season tire starts to lock up as inevitably it will do, the ABS releases the brakes, and a car equipped with ABS will rotate a new freshly wet portion of the tread into the contact patch area.
Originally Posted By: JHZR2
After having used a variety of AA and A traction tires, I cant say that Ive been able to tell a meaningful difference, FWIW.
If the two sets of tires were both all-season tires, you should see no difference, because the water on the tread of an AA rated tire that is permitted to rotate will perform the same lubricating function as the water on the tread of an A rated tire that is allowed to rotate; it is only after the water is scrubbed off of the tread that the tread of an AA-rated all season tire can make a difference.
Originally Posted By: PandaBear
I'd still pick an AA over an A for ABS car, heck, 2 of my 3 cars have no ABS.
The AA tire is especially superior to an A tire on a car that lacks ABS. And, in the real world, where all surfaces are not level and all directions are not straight ahead, the traction of an AA-rated tire will aid the driver in directional control.
