Soliciting oil recommendations for a 2001 Passat 1.8 turbo that triggers the low oil pressure warning at hot idle. Ideally this oil would be able to bump up the hot idle oil pressure (in comparison to the OEM spec 30-40 weight synthetics) which is going to increase in the near future with the weather heating up? The car is run in moderate temp northern Cali and sees mostly in-town short trip driving with occasional long highway jaunts.
I'm considering 1) 15w40 HDEO, 2) 10w40 Redline, 3) Mobil1 15w50, 4) Z blend with some Lucas oil stabilizer
