Was doing the axle seals on my truck today and while doing them I was suprised to see the small amount of gear oil loss come out in a sort of grey color. I had filled the rear diff bout 4 years ago, with Royal Purple 75w-140 gear oil, and I was a little concerned by the color. I pulled the plug to check the fluid level and it is a tiny bit below the hole, but my axle seals have prolly been leaking for a while. Also the magnetic plug really didn't have all that much of a metal coating on it, which kinda gave me the impression that perhaps all was well with the fluid and it just naturally takes on that color with age/use.
Anyone ever cracked open a Royal Purple filled differential and made note of the oil color as it drained. I've seen various colors from other vehicles, but I've never knowingly seen royal purple being drained as to tell if it's normal.
If I weren't unemployed for the past 1.5 years I wouldn't hesitate to spend the $60 bucks and change the oil, but I can't justify the expense if the oil is fine. Later on I can link a picture of a bit of the oil I caught in a plastic cap.
