Ugly New Prius #2
by AirgunSavant
08/28/16 08:32 AM
Getting hurt at work
by ram_man
08/28/16 04:46 AM
Brake Pad Shims a MUST?
by SavagePatch
08/28/16 01:34 AM
Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
75 registered (4WD, 09_GXP, 2010Civic, 2015_PSD, 2009Edge, 2004tdigls, 5 invisible), 1290 Guests and 25 Spiders online.
58943 Members
66 Forums
253659 Topics
#2935435 - 03/11/13 03:19 PM grease gas cap seal?
Digital2k2 Offline
Loc: va
My gas cap isn't sealing completely. I had a locking one on there and took it off because I figured the seal went bad on it. Put the original back on and I can still smell fumes a bit. I tried cleaning the filler neck where the seal contacts and the seal of the cap but it didn't take care of it.
This cap was only used for around 3k miles and is just a few years old with what looks like a silicone seal on it (orange) instead of the regular black seal that the locking one has.
My next thought is to try putting a thin layer of dielectric grease on the silicone seal. Is this a bad idea? The only downside I can think of is that it may catch more dirt and need to be cleaned more frequently. Worth a shot?
#2935438 - 03/11/13 03:23 PM Re: grease gas cap seal? [Re: Digital2k2]
hemitom Offline
Loc: canada
If its already not sealing i think you have nothing to lose, it may soften the gasket enough to work again.
2006 kia spectra
2009 hyundai santa fe
2012 mustang coupe.
#2935458 - 03/11/13 03:40 PM Re: grease gas cap seal? [Re: Digital2k2]
AandPDan Online   content
Loc: MA
Are you sure it is the cap leaking?
Sometimes the filler necks rust out.
#2935463 - 03/11/13 03:41 PM Re: grease gas cap seal? [Re: Digital2k2]
JHZR2 Offline
Loc: New Jersey
MB sells gaskets for their caps. After 30 years sometimes it is needed.
Perhaps the size is the same on all filler necks?
Cut your own gasket from sheet rubber?
#2935469 - 03/11/13 03:47 PM Re: grease gas cap seal? [Re: Digital2k2]
Jarlaxle Online   content
Loc: New England
Make sure whatever you use is gas-proof!
1979 Coupe de Ville, 542 stroker, 15W-40 Super Tech, Delco
2011 Crown Vic P71, 5W-20 Valvoline NextGen, Purolator
2012 Suzuki AN400A, 10W-40 ST, Delco
#2935474 - 03/11/13 03:49 PM Re: grease gas cap seal? [Re: Digital2k2]
mechanicx Offline
Loc: Ohio
I would just replace the cap or the seal. Silicone based seals are the one seal type you shouldn't use silicone grease on, unless maybe you are trying to soften the seal.
#2935567 - 03/11/13 05:19 PM Re: grease gas cap seal? [Re: Digital2k2]
Tegger Offline
Loc: Canada
What year, make, model?
2013 Toyota RAV4 - 57,000 miles - Toyota 0W-20, Toyota filter
#2939244 - 03/15/13 01:13 AM Re: grease gas cap seal? [Re: Digital2k2]
Digital2k2 Offline
Loc: va
Just seems like if it was a bad seal that the barely used original cap wouldn't do it too. I tried a thin coat of dielectric grease on the seal and it didn't make a difference.
The vehicle is an 09 nissan frontier.
