Originally Posted By: mechtech2
Originally Posted By: ARCOgraphite
Thanks GM boy. close enough
this is an easy fire electrode and can be gapped a tad tighter if need be.
You want the electrode "points" parallel so DONT open the gap and end up with a quench happy heeled back electrode. Better to be .005" under gapped then have a lifted gnd electrode.
Racer Engine builder rule # 1313.
Closer gapping will also put them out of parallel - makes your point null and void..
You get more quench with a smaller gap - you have it backwards.
I always gap my plugs about .005" wider. If you are on top of maintenance, this is great. Better spark for cruising/leaner conditions, and less quench - better in and out flow.
The platinum nibs get rounded anyways - parallel is not a concern.
This Denso TT is a special plug with two plat/Ti hard points. It was supposedly "factory gapped" at .040" so wouldnt open it to 0.043" (1.1mm) Opening the gap (heeled back) puts the spark kernel near the GND strap shell tie in which is cold and shrouded. Agreed that there are so many other factors influencing spark, including indexing - which street guys prob shouldnt do. BTW Packard/DELCO made the the best ignition wire when I was building engines.
