Cheap brake fluid tester working properly?
by LucasDK
05/28/16 04:00 AM
Help finding specific oil.
by Mickxalix
05/28/16 02:28 AM
Found at Walmart: STP Multipurpose Motor Treatment $1.50
by MrQuackers
05/28/16 01:36 AM
Mobil 1 5w50 now FS too
by BobFout
05/27/16 11:55 PM
Front brakes for 1991 GMC Sierra 2500
by sr17
05/27/16 11:35 PM
7200 Miles
by Yup
05/27/16 11:08 PM
Result; 5 additives tested in a lab
by DrAdmin
05/27/16 09:25 PM
What are advantages of rotation ?
by HTSS_TR
05/27/16 09:22 PM
Arthritic joints
by Eddie
05/27/16 08:55 PM
Trouble Installing Filter
by Astro_Guy
05/27/16 08:09 PM
Kia P0138 Code From Old Amsoil Stabilizer ??
by Quadrasteer
05/27/16 07:43 PM
Micro Guard Filter
by Jason1221
05/27/16 07:38 PM
troutwest66, AIRJAC3, bpete65, LEVY, Timmytimmy
58000 Registered Users
28 registered (Bandito440, Char Baby, dlundblad, crazyoildude, bdcardinal, 2 invisible), 495 Guests and 330 Spiders online.
58000 Members
66 Forums
249510 Topics
Page 2 of 3 < 1 2 3 >
#2937607 - 03/13/13 02:04 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: Donald]
KHP Offline
Loc: Reno, NV
Originally Posted By: Donald
PU
+1
Both are excellent oils, if you can easily acquire PU locally then I say go for PU. I do prefer PU over M1 on my Turbo Subaru. Either way I don't think you can go wrong.
Edited by KHP (03/13/13 02:08 PM)
2011 Impreza WRX Limited (46k Mi): OCI = 7.5K Mi - Pennzoil Ultra 5w/10w30 - OEM blue oil filter/P1 PL14612
#2937635 - 03/13/13 02:34 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: ajwan]
buster Offline
Loc: NJ
Quote:
The Ford Ecoboost 3.5 can be hard on oil - fuel dilution is a worry.
Both are top notch. Edge would currently go to PU, but it would be close. I say run both and do a UOA. If fuel dilution is an issue, keep your drains short. Also, some oils that use little to no viscosity index improvers, (your 10w30 synthetics with Low viscosity index) can sometimes hold up better when fuel diulution is an issue.
#2937636 - 03/13/13 02:35 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: OVERKILL]
buster Offline
Loc: NJ
Originally Posted By: bigt61
Turbo? Heat? Is it driven hard at all? No way I would go with M1 AFE - phosphorous only 650ppm. In a Hi Performance vehicle with a Turbo, that's a recipe for disaster IMO. Regular M1 5W-30 might be marginal at 800ppm. Maybe M1 5W-30 Hi Mileage or the Turbo 5W-40. If you use the 0W-30 AFE, drive it gently, the low shear might be another concern.
http://www.mobiloil.com/USA-English/MotorOil/Files/Mobil_1_Product_Guide.pdf
It has Ford's approval. There are other anti-wear additives of the organic variety being used in these new cutting-edge fomulas, components that don't show up in a UOA.
And I'm confused as to your correlation between a turbo (high heat) and phosphorous (high valve spring pressure, cam lobe protection). An oil with high quality base oils that resist heat well are certainly suitable for use in a turbo application, and the oil in question is of that variety.
Right. Mobil 1 currently uses the latest in additive and base oil technology. You can't judge an oil by a VOA.
Mobil 1 0w30 also meets GM 4718M, and I believe now dexos 1. It also has a good slug of PAO in it. 40% I believe.
#2937639 - 03/13/13 02:40 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: ajwan]
bigt61 Offline
Loc: Virginia
Well, if he drives it like Grand Ma, I'm sure the 0W-30 will be fine - and he does live in Vancouver so cold starts would be a benefit. 0W-40 might be the better choice though.
https://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_0W-40.aspx
https://www.mobiloil.com/USA-English/Mot...bo_Engines.aspx
92 Suburban 2500 7.4L 58k M1_5w30 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 29k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#2937678 - 03/13/13 03:21 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: bigt61]
ajwan Offline
Loc: Vancouver, BC, Canada
LOL! I'm pragmatic. Totally a grand-ma during my daily commutes. But I will let her rip on occasion on highway entrances and during passing maneuvers!
#2937684 - 03/13/13 03:27 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: volk06]
ajwan Offline
Originally Posted By: volk06
Use the PU due to its very low NOACK. This may help with deposits. This lineup is too young to tell if deposits will be a issue.
This may very well swing me to use PU. Ford claims to have at least minimized the deposit issue according to this patent:
http://www.google.com/patents/US6178944
#2937692 - 03/13/13 03:33 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: ajwan]
Coprolite Offline
Loc: TX
I would use 0w-30 before using 0w-40 when under warranty for my 3.5 Ecoboost. That being said, I have more than three changes worth of PU 5w-30 lined up and have my eyes on more if it goes on clearance.
#2937699 - 03/13/13 03:38 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: ajwan]
bigt61 Offline
Loc: Virginia
Nice find - I knew someone would eventually figure out a way past the carbon forming on the intake valves of DGI engines. I wonder if other people will "copy" Ford's method or have to license it from them.
70 Camaro 5.7L 59k
#2937711 - 03/13/13 03:48 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: ajwan]
Coprolite Offline
Loc: TX
Other companies are putting out a hybrid injection system. Audi is one that springs to mind.
#2937714 - 03/13/13 03:49 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: ajwan]
A_A_G Offline
Loc: D-town
If I owned a Focus ST, I'd personally go with M1 0w-40.
#2937736 - 03/13/13 04:17 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: A_A_G]
ajwan Offline
Wouldn't fuel consumption concern you by going with a 40 weight? Granted fuel consumption is typically an afterthought on a performance vehicle. But the interesting thing is that many owners bought an ST over others because it very nicely combines practicality, performance, and fuel economy (I live on focusst.org). Ford advertises 22 city/32 MPG highway (26 combined). Most appear to have a very difficult time achieving the 32 number, myself included.
Regards.
Edited by ajwan (03/13/13 04:19 PM)
#2937960 - 03/13/13 08:05 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: ajwan]
ajwan Offline
The problejm I have now is that neither of these oils are even available to us in the Great White North. Will have to make a special trip to Bellingham just to get these oils!
My long term preference is for PU Euro 5W-30 as it is low SAPS and carries the VW504/507 spec. Unfortunately, we will never find this oil in NA. PU it is then.
#2937989 - 03/13/13 08:36 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: Coprolite]
volk06 Offline
Loc: Iowa
I might sneak an OCI of M1 0w-40 into my ecoboost next go around. This OCI will be about 3K per the OLM (65% @ 1K) in the past 4 months. OCI will be done with engine hours and not miles. As long as I get it to the dealer before its been a year and 10K since my last visit...they will never know.. lol With the fuel dilution and shearing it'll be a 30wt after 1000 miles anyway. Have to use up my stash of oil before I buy more though so more than likely it will be out of warranty when I try the 0w40.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#2938023 - 03/13/13 09:11 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: buster]
kr_bitog Offline
Loc: South East Asia
50% i believe there is a reason why the product listed on the sequence EP, standard, AFE, HM on the website :-)
#2938085 - 03/13/13 10:11 PM Re: Pennzoil Ultra or Mobil 1 AFE for Focus ST? [Re: A_A_G]
Hyde244 Offline
Loc: Ohio
Considering Ford doesn't make the jump up in oil weight from 30 until you hit their 5L and 5.4L Mustang engines - 0w40 would be overkill.
Stick with the 30 weight oil as it matches the proper Ford specs for a Focus ST.
2007 Ford Focus ZX4 SES - 2.0L Duratec | 4F27E Auto | 92,000 miles
PU 5w20 | MC 910 | Castrol Mercon V
