To be honest, I fail to see how smog test is that big of a deal unless you intentionally modify your car for some silly reason (take out the CAT). They have a very big tolerance that unless you have something went bad on your car (which you should fix anyways), you will pass.
I blame the problem on people running with a bad O2 sensor, gutting their cat for rice out, backyard turbo that wasn't tuned, never changing their spark plugs, etc for giving the rest of the people problem. It is not hard to pass, they are not out to get you unless you intentionally do something.
and PM2.5 is bad but they are mostly a coal fire power plant problem. Don't believe me? look at the air quality in Beijing.
