Originally Posted By: yonyon
Originally Posted By: LeakySeals
I switched the PGL BECAUSE of the dex sludge problems. And I'm STILL experiencing problems with dex sludge. The sludge was there BEFORE PGL or RMI-25 when it was ALL DEXCOOL. Why i changed at all. would stay with factory spec if all was fine. but it wasn't, I had to do something. The pictures are remaining dexcool sludge. There is no missing part of the story. I made a change to fix a problem. Hope that helps clear the confusion.
Please forgive my jumping to conclusions as I just ran across this and am too lazy to scroll back, but are you having a problem with cooling system slime in the Grand Prix? If so, please consider that you might be dealing with W-slime and not Dexsludge.
Those prolific W-body GMs with the 3800 pretty much all also came a defective radiator. The ATF cooler has a very pretty weld that looks like something to be proud of if it were made by a man instead of a robot. That weld is all kinds of thin and tends to erode causing a leak. I estimate that 4 out of 5 of these 3800 powered Ws I see have a leaking trans cooler.
I don't care to guess about whether or not a different coolant chemistry would have allowed the flawed weld to hold up longer than the Dex, but in the end, once the cooler is leaking you aren't going to fix it just by replacing your coolant.
What would be some visible symptoms? Would I be experiencing a problem with the tranny due to cross contamination or a loss of transmission fluid? would the transmission fluid be noticeably discolored? Empty or overfilled? I just looked, don't see anything unusual. This is my first Dex VI car so I'm not 100% on what Dex VI fluid should look like. Its not red, more of an amber. Very clear, hard to see on the stick its so clear. Level looks slightly under because its cold. Shifts fine, a little tight getting in and out of gear in the morning (Compared to the Camry). Clunks a little putting it in reverse or drive. I don't consider that unusual, just the way the GM transmission is I assume.
