Originally Posted By: Trav
I have this one from OTC, Its good quality and does a good job on struts off the car.
Its safe even with heavier springs like those found on Honda odysseys in the front.
One spring compressor cant do every job like MB 123 cars require a special one, for those and quite a few similar styles one i use one from Klann.
You cant go wrong with this one from OTC for most struts it will do a good job.
HF makes a copy of this that would scare me to death.
I have a painted red re branded one of these, I think it's a Mac or Matco. Sorry, it's been a while since I have done any strut work. I've done several sets of struts on older Camry's with it, although there is a warning not to do so! I am barely able to get the spring compressed enough to remove/reinstall it safely. And it is scary. Anyone not afraid of a compressed spring will probably get an education one day.
It is a good tool, far better than cheapie spring compressors. And yes, I have 2 pairs of those in bottom of the toolbox. The best part is the ability to use an impact wrench on it. That saves so much time and effort. I think it's the best option short of a wall or floor stand mounted version like a Brannock. Just be sure to read all the warnings on which cars can use this style compressor. As mentioned above, more than a few can not.
If you are really worried, maybe you can find a shop that will swap the springs for you. You could save a lot of labor dollars removing and re-installing the assemblies yourself.
