Hate those adds that start with, "Lean 1 weird ...
by OneEyeJack
04/30/16 05:11 AM
How Much Olive Oil Do You Use?
by GrtArtiste
04/30/16 03:20 AM
Hyundai filter 26300-35503 10PK for 35.40 FREE S&H
by GumbyJarvis
04/30/16 01:10 AM
Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
04/29/16 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
04/29/16 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
04/29/16 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
04/29/16 09:16 PM
UPS package tracking is so confusing!
by Klutch9
04/29/16 07:52 PM
Dupont non-stick lube
by buck91
04/29/16 07:47 PM
House electrical wiring question
by road_rascal
04/29/16 07:46 PM
Air pressure question
by aquariuscsm
04/29/16 07:43 PM
Fllow the DOT's
by WyrTwister
04/29/16 07:23 PM
hdwizard21, raihan, aceracres, kg4geq, red_bulldog
57748 Registered Users
36 registered (06AllAmerican, 2002 Maxima SE, Al, Abakev, AEHaas, 1foxracing, 3 invisible), 709 Guests and 295 Spiders online.
57748 Members
66 Forums
248234 Topics
#2932354 - 03/08/13 08:29 AM CV Boot leaking
cyclehead Offline
Loc: GA
My CV boot suddenly started slinging grease from the band on the axle shaft. The boot is perfect with no cracks. The car is rear-engine so I don't have any "turn the steering wheel" options to check for noises. My questions: Does the grease slinging out indicate that the CV joint is overheating and failing? Would you recommend a symptomatic fix by just installing a tighter band to stop the grease coming out? Would you recommend peeling the boot back, and repacking the joint with new grease?
Thanks all!
#2932361 - 03/08/13 08:35 AM Re: CV Boot leaking [Re: cyclehead]
zzyzzx Offline
Loc: Baltimore, Maryland, USA
If it were my car I would replace the axle with a new one.
#2932362 - 03/08/13 08:38 AM Re: CV Boot leaking [Re: cyclehead]
Tboss Offline
Loc: Atlanta GA
I would replace the axle if it was my car
#2932366 - 03/08/13 08:42 AM Re: CV Boot leaking [Re: cyclehead]
Miller88 Offline
Loc: Onondaga County
The grease is coming out for one of two reasons: Something ripped the CV boot or the CV boot got old and dried up and cracked.
There are kits out there to rig up a boot ... but they don't always work well.
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
#2932385 - 03/08/13 09:07 AM Re: CV Boot leaking [Re: cyclehead]
zzyzzx Offline
How many miles on this axle? I don't trust them past a certain point. They wear internally and get loose, even if the boot doesn't break.
#2932386 - 03/08/13 09:07 AM Re: CV Boot leaking [Re: cyclehead]
Kool1 Offline
Loc: California
On my 03 CRV I replaced the front axle only 20,000 miles ago. Last week I noticed that the cv joint leaked due to a slightly loose band clamp. I check my undercarriage often and caught the leak early. I replaced the clamp with a universal Dorman clamp for around $5.00 and all is well. Getting the old clamp off was difficult as a wire cutter couldn't cut the old clamp and a tin snip could not grasp the old clamp without possibly ripping the boot. I had to borrow a special tool from a friend to get the old clamp off. The new clamp is only like a metal tie wrap; not a thick qualtiy part like the Honda part but it does the job.
#2932389 - 03/08/13 09:10 AM Re: CV Boot leaking [Re: Kool1]
zzyzzx Offline
They ran out of hose clamps at Home Depot???
#2932412 - 03/08/13 09:28 AM Re: CV Boot leaking [Re: zzyzzx]
Kool1 Offline
Loc: California
I thought about using a worm drive hose clamp versus the Dorman metal zip tie clamp. I decided on using the Dorman clamp as it said on the package that it's for CV joint boots.
#2932424 - 03/08/13 09:36 AM Re: CV Boot leaking [Re: Kool1]
cyclehead Offline
Loc: GA
I'll try the dorman clamp. My boots are in excellent condition, and the axle only has 25K miles. I understand that hardware store clamps are too wide. Would you suggest adding grease, or repacking with grease?
#2932489 - 03/08/13 11:02 AM Re: CV Boot leaking [Re: zzyzzx]
HerrStig Offline
Loc: Boston, MA
+1
#2932492 - 03/08/13 11:03 AM Re: CV Boot leaking [Re: zzyzzx]
HerrStig Offline
Loc: Boston, MA
They ran out of hose clamps at Home Depot??? +1
#2932638 - 03/08/13 01:45 PM Re: CV Boot leaking [Re: cyclehead]
gomes512 Offline
Loc: Chicago, IL
Depending on the mileage and how early you caught it I'd just pack some more CV grease in it and throw a new band on it, the local Autozone by my place rents the tool to get the band on there.
Some of the folk around here drive on joints that make more clatter than a passing freight train, I'm sure your no where near that point.
I've tried worm drive clamps before but they pinch the boot under the screw and allow leaks.
#2932660 - 03/08/13 02:19 PM Re: CV Boot leaking [Re: cyclehead]
Tegger Offline
Loc: Canada
Depends how much has leaked out. If it's only a little, then just wipe everything off and install the new band as tight as you can get it. The problem is that, beyond seeing what obviously got slung out, it's going to be really difficult to tell how much new grease to add. a joint that's a bit low on grease will still run for a very long time. I'm not sure what would happen if it had too much grease.
Try and get the boot/shaft joins as dry as you can before installing the new band. Any grease or film will allow seepage for a very long time. That's not harmful by itself, but it will look unsightly.
2013 Toyota RAV4 - 50,000 miles - Toyota 0W-20, Toyota filter
