I recently aquired a refurbished Wagner Twin Stroke 9155 airless sprayer. I was going through the setup and cleanup instructions and in the manual, for "Long Term Storage" which seems to be anything longer than 16 hours, that you should put a cup of either separating oil (Wagner P/N 0516913) or just plain household oil.
In the past on a different Wagner airless sprayer I just filled the inlet with 3 in 1 and that seemed to work fine. However on this new-to-me sprayer, it's a highboy and the inlet is facing straight down. This makes it more difficult to just fill the inlet port and pump it out. You would have to turn the sprayer upside down to do that. I tried that last night and it just makes a lot of mess and wastes the light oil that you are ostensibly lubricating the pump and piston with.
So it occurred to me that I might want to buy a large amount of light household oil, so I could fill up a small cup to put underneath the intake, so that the pump can pull the light oil up into the device. But last night I was shopping at Walmart and it appears they don't have any large quantities of light household oil like 3in1, WD-40, Pblaster, etc.
So then I walked down the oil aisle and thought, what's the lightest oil they have in the automotive section? 0w20 is probably still way too thick for the application. Then I noticed the gallon of Supertech TC-W3 for like $12. It would take me a long time to go through that whole gallon a few ounces at a time. It seems pretty thin. Maybe could be mixed with a light solvent like paint thinner to make it even thinner?
But is TC-W3 suitable for this task? I guess my concern would be the level of ash content in the TC-W3 oil, maybe it's too much for a paint sprayer. I don't suppose anyone's done a VOA on 3in1 or the Wagner OEM "separating oil". Maybe someone's done a VOA on TC-W3?
Opinions? Suggestions?
