Just curious to what you guys are using in your 07-2013 Acura MDXs..
I recently learned that both local dealers don't use OEM Honda/Acura oil. But instead contract with Chevron lube.
I have 0 issues doing oil changes on my own. I've been going to the dealer assuming they used Honda/Acura oil plus entering the info for my VIN so it shows regular/routine oil changes. But now im having second thoughts. I don't know anyone that "chooses" to use chevron oils.
So what do you guys think? Should I continue going to the dealer since the vehicle is "fine"? Should I try something typical over the counter, or should I order up some Honda/Acura oils?
