Here's the deal....
- Two cars ('97 Volvo 850, 2.4L, non-turbo && 2008 Toyota Corolla, 1.8L)
- Temps (Will have gotten down to 32 deg F just four days this winter, but pretty much stays in high 90s for half the year)
- Want full synthetic
- Know somebody who deals Amsoil and can sell it to me for the price they get it for (15% off?). Is Amsoil worth the price that the reseller pays?
- Is the German Castrol really worth hunting down? I'd more than likely prefer something I can pick up anywhere locally.
- When, if ever, is 0W-30 or 0W-40 a bad idea??
- Toyota recommends 5W-30 in my Corolla's manual, but I've seen that they also started recommending 5W-20 for these same 1ZZ-FE engines, and they even recommend 0W-30 and 0W-20 in certain cases.
- I've heard that 0W-30 works just as well if not better than 5W-30. What about for my temps?
- Volvo recommends 10W-30 in my 850's manual, but I've seen that they also started recommending 5W-30, and perhaps other weight oils.
- I've compression tested this Volvo and got 212 psi, which is quite healthy of the preferred 189-219 psi range (non-turbo).
- I've only been running regular dino oil in this car up until now because it was leaking oil, but I've figured out why it's leaking and am in the process of fixing it now.
- Thinking about using the Shell Rotella T6 5W-40 in this car. Maybe a different 5W-30 or 0W-30 would work just as well, tho??
