Oh, it'll suck it out all right - No Problem. My question is why do you want it all the time ? I mean, if your truck is set up to run normal fuel, and is in decent state of tune, you shouldn't need it all the time. No high compression pistons/chambers to worry about, just do it for a jug or so and then drive it normally, knowing you've done your part to clean up the innards of your engine and go from there. Maybe again, as needed, in future, but your driveability may suffer on a constant basis without enough reason for the added "moisture" in the chamber all the time. Or if you do it constantly, u wont need a very big needle or it'll likely be too much for it to handle running on and consuming all the time.
