I am trying to replace the brake fluid in my 2008 Sienna LE. I am able to crack the bleed fitting on three wheels and have fluid flow out the fitting as someone pushes the pedal to the floor, but on the right rear, there is something stopping the flow. I crack the fitting while my wife is pressing on the brakes and I get about two inches of fluid (VERY SLOWLY) into the tubing connected to the tubing before the flow stops. The pedal never goes to the floor no matter how hard she presses the pedal. I have verified that the fitting is not clogged.
I know on older cars that the proportioning valve could cause problems like this, but I don't know if that is still a possibility with modern vehicles.
It is curious that I get some flow initially and then it stops. Since it does flow, if nothing else is stopping it but some type of constriction, it should still slowly flow until the pedal hits the floor. So I wonder if there is not some other component that is stopping the flow.
Anyone else know about this issue?
