Here is the report:
Aluminum - 3
Chromium - 1
Iron - 19
Copper - 11
Lead - 1
Tin - 4
Moly - 43
Nickel - 0
Manganese - 1
Silver - 0
Titanium - 0
Potassium - 1
Boron - 48
Sodium - 9
Calcium - 893
Magnesium - 1128
Phosphorus - 1058
Zinc - 1252
Barium - 0
SUS Vis @ 210F - 65.6
cST Viscosity @ 100C -11.77
Flashpoint - 395
Fuel% - Antifreeze% - 0
Water% - 0
Insolubles - 0.2
TBN 4.6
This is the 6th UOA I've done on the bike since 2001. It is a flat 6 cyl, with a redline of 6500, and generally never goes above 4000, as I am easy on it. The oil was in place just 2 weeks shy of 1 year.
The previous oils tested were Amsoil 10/40 in 2005, Mobil Truck & SUV 5/40 in 2006, Rotella 5/40 in 2006 & 2007, Mobil 1 10/40 MCycle oil in 2006, and now Delo.
Frankly, I am not impressed with this result, and fact, am very disappointed in it. The oil stayed in grade, it shifted decently, but when you compare it against the other oils I've test, it's in last place. In fairness to Chevron, they don't advertise this as an acceptable motorcycle oil.
The TBN started at 10.5 and in less than 2,000 miles, it was cut in 1/2.
This UOA was the worst of all, when projected to approximately 3,000 miles of use, the wear metals would be as follows, the best to the worst:
1. Rotella 5/40 syn - 22ppm
2. Rotella 5/40 syn - 25ppm
3. Mobil 1 1040 Motorcycle Oil - 28ppm
4. Mobil 1 5/40 Truck & SUV - 40ppm
5. Amsoil 10/40 Motorcycle Oil - 52ppm
6. Chevron Delo 5/40 syn - 61ppm
Delo has nearly 3 times the wear when projected.
I am the original owner on the bike, the style of riding has been the same since owning it.
I am not certain now that truck CJ oils provide the same protection as they did when I used Shell Rotella back in 2006 and 2007, which is causing me to re-think using them.
When I sent the sample, I re-filled with Chevron Delo 15/40, but at this point, I am going to dump it today and go back to Mobil 1 10/40 motorcycle oil.
I had high hopes with Delo, but they were crushed with this report.
Thoughts?
RevRider
Aluminum - 3
Chromium - 1
Iron - 19
Copper - 11
Lead - 1
Tin - 4
Moly - 43
Nickel - 0
Manganese - 1
Silver - 0
Titanium - 0
Potassium - 1
Boron - 48
Sodium - 9
Calcium - 893
Magnesium - 1128
Phosphorus - 1058
Zinc - 1252
Barium - 0
Flashpoint - 395
Water% - 0
Insolubles - 0.2
TBN 4.6
Thoughts?
RevRider
