I am still goofing around with the shocks on my truck. Right now I have a set of Gabriel Pro-Guards on front and rear. They are similar to or maybe a little better than an OEM type ride. Before those I had Rancho RS5000 front and rear. They rode real stiff so that is why I bought the Gabriels. Now that I have had the Gabriels for almost 3 months they still seem to be kind of soft and bouncy. I feel a lot of the bumps in the road, I can even feel it when I drive over the white turn lane arrows on the road. I tried lowering my tire pressure to 32.5 psi, it feels like it helped a little but I should not have to do that to fix this problem. I always ran my tires at 35 psi before this problem with the shocks.
I still have the Rancho's I took off the truck last year. They were special ordered so I can not return them. I tried to sell them here and on Ebay but no one wanted them. When I drive my truck I feel a lot of the bumps in my lower back and butt. This makes me think that it might help to put the stiffer Rancho's back on the rear and leave the softer Gabriels up front. Does that make sense or should I put the stiffer Rancho's up front and keep a softer shock in the rear? I do not tow or haul anything heavy and my truck is only a 2-wheel drive V6. I do not go off road. Tires are BFG Long Trail T/A Tour, P235/75R15's, they only have about maybe 17,000 miles on them.
I have checked the front end components, a lot of it is either new or not too old and all is in good shape. The leaf springs and coil springs seem to be OK but the only way I know to test those is just by measuring the height..
I appreciate any help on this. I need to figure out what is wrong. I had Monroe Reflex before all this, those rode great, and if Monroe still made the Reflex for a 2 wheel drive Dakota I would have got another set when I started this process last year.
Thanks.
Thanks.
