Originally Posted By: Cujet
Originally Posted By: supton
22's are not well "sealed" -- often I can spin the bullet relative to the case. Moisture can then ingress.
So true. 22 ammo often does not store all that well. I have some older ammo from the 60's and 70's. Mostly duds.
The CCI ammo that is waxed seems to hold up well and last for years. It's not really sealed, but the wax does seem to do the job fairly well.
22 ammo hoarders need to consider keeping the ammo in a sealed and completely moisture free environment. Special storage is the only way to ensure viability. Putting it in an ammo can is not likely to be good enough over the long term.
What is wrong with storing ammo in ammo can long term? I've done it for years, over 30, I have never had any ammo go bad, not once.
