I have a 2007 Elantra here that is nearing 60k miles.
The car was originally from Canada, fwiw, which may/may not make a difference.
The factory service manual states that the BKR5ES11 NGK copper plugs are the correct spark plugs.
However, the factory maint schedule says to replace the spark plugs every 60k...with a parenthesis that the plugs are platinum.
To further complicate matters, I looked up spark plugs for a 2008 Elantra (same car) and the factory service manual says that it calls for a NGK IZFR5L-11 OE Laser Iridium plug.
So, has anyone changed plugs on a 2007 Elantra? What are the correct plugs for a 2007?
Thanks.
Thanks.
