The trans fluid in this 4L60E (2003 Envoy 4.2) is likely original at 120K. There are no symptoms of flare or slippage and has been driven easily it's entire life, no towing or jack-rabbit starts.
The current (2nd) owner has had the vehicle since about 25K and hasn't changed the fluid. Fluid isn't dark but slightly brown with the slightest hink of pink and doesn't smell remotely burnt or even abnormal...just absent is the fresh fluid smell.
My question is.... should I change all the fluid now, or change the pan capacity and let it go for a while then after maybe 1K miles flush everything?
My gut says not to change all the fluid initially to avoid excess cleansing but not sure.
