56.5 miles ago, I poured 3qt of Rotella T6 5w40 and 1qt of Mobil 1 0w20 (to thin the mix) into my 2000 Corolla. I had the valve cover off immediately before the OC to clean and enamel it and replace the worn valve cover gasket before it started leaking. I had the valve cover off again tonight to take the cover of the VVT-i cam and peek at how dirty it was in there (more on that at the end of the post). What I saw tonight surprised me, so I grabbed the camera.
Timing chain and cylinder 1 and 2 cams
BEFORE:
AFTER:
Cylinder 3 and 4 cams
BEFORE:
AFTER:
Look at the cleaning going on here, there's just a spot of varnish left on that camshaft clamp:
Exhaust timing gear looks like new:
Check out the cleaning going on here, behind the camshaft:
And now, for the reason I took it apart to begin with; the VVT-i gear innards:
I was expecting it it be dirty as heck in there, but it's super clean! I was able to slide the outer ring half way off with ease, at which point I stopped, so the nylon seals and pressure-plates wouldn't fall into the engine, but everything was moving freely (though not rotating, since the locking pin was engaged). I put the spring back in bolted the plate back down after taking the following two photos:
VVT-i cover plate:
The locking-pin spring seems to be wearing a groove into the plate:
Look at how deep that is! It seems to function fine, so I'm not gonna worry about it for now.
Angles in the comparison shots may vary, but the lighting conditions are the same. All photos, before and after, were shot in my garage, which has 24/7 florescent lighting, while I was holding an LED flashlight against and perpendicular to the left side of the camera body.
I could not believe my eyes when I saw the cleaning after only 56.5 miles! Rotella T6 is the s**t! Okay, maybe the M1 has something to do with it, or maybe I've stumbled across some magic brew here, but the oil is 75% T6 so I'm gonna give it all the credit.
This engine was clean to begin with -- now it's even cleaner!
EDIT: Camera detials: All photos shot with a Canon PowerShot SX50 HS in full manual mode. Before shots were shot at ISO1600 f5.0 with shutter speed varied to balance lighting. After shots were shot at ISO6400 f5.0 to allow for higher shutter speeds and less blur, shutter varied for light balance. The lack of yellow hue in the AFTER shots is not a result of lighting or camera settings, as lighting and white balance settings have remained constant; use the gasket-contact surface of the block for calibration, the yellow is actually gone in the AFTER shots.
BEFORE:
AFTER:
BEFORE:
AFTER:
VVT-i cover plate:
