I received this this report from Blackstone.
My 1st sample was run for 3400km only.
Do aluminium and copper increase linearly with kms ?
If yes it looks as if both oils produce about the same wear per km on these two metals, correct ?
This oil has thinned, from 11,1 to 8,54
This has also has happened to my previous sample (oil used was redline 5w20). From 9,1 to 7,71
Why do you think this has happened ? Could this be due to fuel dilution ? (as the redline person suggested to me). Here is his complete reply back from April 2011:
Quote:
The oil analysis basically looks good, the wear metals reasonable, though without history don’t have a normal base line to reference.
The 5W20 is completely sheer stable, it will not sheer down and loose viscosity so that reading is either a bad number or there was significant fuel dilution. The fuel dilution doesn’t show up in the analysis but could have been missed, the flash point being about 100°F low would also be an indication of substantial fuel dilution.
A higher viscosity would be advisable with that suspected fuel dilution.
Regards, Dave
Red Line Oil
Could it be some other reason ?
Similarly I see the flash points of both oils decreased significantly.
Also note that I am using evans coolant which has no water.
Could it be some leak?
Is this an indication that I should use an even thicker oil ?
Should I use 10w40 or should I investigate something ?
My apologies for the chaotic structure of my questions.
Regards, Dave
Red Line Oil
