Who uses Quicksilver Multi-purpose oil
by BrocLuno
07/30/16 08:07 PM
Gumout Q&A with Ryan Tuerck - Answers
by wwillson
07/30/16 07:37 PM
Friend Picked Up New 2017 Hyundai Santa Fe Today
by crazyoildude
07/30/16 07:07 PM
15.5hp kawasaki engine uoa
by motor_oil_madman
07/30/16 06:25 PM
Best way to remove old tape pin striping
by 007
07/30/16 06:10 PM
Fram Ultra XG-2 Holes On Center Tube
by crazyoildude
07/30/16 06:03 PM
New Dillon CV-2001 Tumbler
by 2015_PSD
07/30/16 05:16 PM
Any video gamers?
by NavyVet88
07/30/16 04:40 PM
Full Synthetic High Mileage Oil
by jsjonz01
07/30/16 04:38 PM
Road trip on new vehicle?
by mrjlube
07/30/16 03:54 PM
Oil Infatuation
by Passport1
07/30/16 03:43 PM
FREE T-SHIRT, $10, AND GOD KNOWS WHAT ELSE....
by macarose
07/30/16 03:16 PM
danthemann, rodder98, kenb777, Indyfan3, RM53119
58651 Registered Users
82 registered (andyd, Alex_V, 901Memphis, aquariuscsm, 007, 2009Edge, 8 invisible), 1787 Guests and 7 Spiders online.
58651 Members
66 Forums
252462 Topics
Page 1 of 2 1 2 >
#2899943 - 02/08/13 07:51 PM Pentastar 3.6 oil pressure
The_Captain Offline
Loc: Upstate S.C.
I wanted to know if any forum members had any insight on Pentastar oil pressure issues. I have a 2012 Jeep Cherokee 4X4 with 3900 miles. Now to the issue. My oil pressure runs between 68 to 80 psi until the oil temp hits approx 158 degrees. It takes several miles for the temp to reach that with the factory oil cooler.Once the oil hits the right temp the pressure drops to around 30 psi.Anybody have any thoughts, theories ,similar experiences or info on this engine? Thanks
P.S. The oil temps never goes above 179/180 degrees
Edited by The_Captain (02/08/13 07:59 PM)
2015 Jeep Grand Cherokee 3.6L V6 4WD Kendall Full Synthetic w/NAPA Gold filter
#2899950 - 02/08/13 08:09 PM Re: Pentastar 3.6 oil pressure [Re: The_Captain]
coolbird101 Offline
Loc: South Florida
Our pentastar equipped vehicle did the same, I beleive the oil pump is 2 speed, runs on high until temp comes up and than anything over 3k rpm (not sure about exact rpm) the pump runs on high.
2013 Mazda 6
Valvoline Synpower 5w/30
Motorcraft fl400s
2005 Dodge Ram hemi
Mopar m-090
#2899974 - 02/08/13 08:34 PM Re: Pentastar 3.6 oil pressure [Re: The_Captain]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
Couldn't it be because the oil is thicker and the engine is a tight tolerance engine which equals more pressure
2004 Honda civic vp -m1 5w30
1998 Saturn sl2 -mobil super 5000 5w30
#2899977 - 02/08/13 08:36 PM Re: Pentastar 3.6 oil pressure [Re: The_Captain]
RiceCake Offline
Loc: Coldtown, Canada
Tolerance =/= clearance.
#2899997 - 02/08/13 08:54 PM Re: Pentastar 3.6 oil pressure [Re: The_Captain]
coolbird101 Offline
Loc: South Florida
For me it would be an abrupt drop, not gradual like oil thinning.
2013 Mazda 6
Motorcraft fl400s
2005 Dodge Ram hemi
Mopar m-090
#2900005 - 02/08/13 09:02 PM Re: Pentastar 3.6 oil pressure [Re: coolbird101]
The_Captain Offline
Loc: Upstate S.C.
Same for me. It is almost instantaneous. 70 psi down to 30 psi in a few seconds.
#2900009 - 02/08/13 09:05 PM Re: Pentastar 3.6 oil pressure [Re: The_Captain]
BillyTheKid Offline
Loc: ny
My jeep runs about the same oil pressure.
#2900032 - 02/08/13 09:45 PM Re: Pentastar 3.6 oil pressure [Re: The_Captain]
Gabe Offline
Loc: Indiana
I thought that the Pentastar has some goofy electric oil pump set up.
#2900062 - 02/08/13 10:31 PM Re: Pentastar 3.6 oil pressure [Re: The_Captain]
Billy_D Offline
Loc: midwest
Quote:
A chain-driven, vane-type variable displacement oil pump adjusts the flow rate and pressure as commanded by the engine management system, which uses a solenoid to drive the pump into low or high pressure mode. For example, below 3,500 rpm, the pump conserves energy by using low pressure; at speeds over 3,500 rpm, the pump switches to high pressure.
A force balance mechanism inside the oil pump adjusts the size of the pumping chambers to alter oil flow. If the oil is cold, the pump reduces the size of the internal chambers. When the oil is hot and thinner, more oil is needed, and a spring increases the size of the pump chambers. This also saves energy.
The pump is driven at a 1:1 drive ratio; its location under the block is more efficient than an on-crankshaft location. An internal, mechanical ball-and-spring relief valve dumps oil into the sump when needed, for conditions such as a cold start with high engine speed. Both pump and pressure regulation solenoid are non-serviceable.
Source Pentastar.com
#2900073 - 02/08/13 10:55 PM Re: Pentastar 3.6 oil pressure [Re: The_Captain]
chubbs1 Offline
Loc: Merritt Island FL, USA
I have 2 2012 Charger SXT's with the 3.6 Pentastar. I have been very happy with them. The oil pressure (OP) is very much like yours, when the temp of the oil reaches approx 174F the pressure goes from the 70-80PSI range to 35-41PSI range. The hottest my oil has gotten is 214F in stop and go traffic mid summer. The Lowest the pressure has gotten is 25PSI at idle in drive. I do find it "funny" that at exactly 174F the pressure drops but pressure is higher with thicker oils and thinner oils cause lower readings.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2900090 - 02/08/13 11:24 PM Re: Pentastar 3.6 oil pressure [Re: chubbs1]
crazyoildude Online   content
Loc: New Jersey
i have heard of problems with those engines but have never seen any at my engine shop. A lot of new engines have ticks and knocking sounding noises that do not do any damage. Some have loud vvt some have other noises but a lot of the new engines seem to be a lot louder than the older ones.
Will Not Use Oil Filters With Those Tiny Restrictive Looking Louvers! Also Not A Fan Of Oil Jugs That Don't Have A Security Inner Seal..
#2900182 - 02/09/13 06:58 AM Re: Pentastar 3.6 oil pressure [Re: The_Captain]
Hokiefyd Offline
Loc: Top of Virginia
I had a rental Chrysler 300 a few months ago and the oil pressure behavior was the same as you are observing. It's 75-90 psi for a while, then BAM, it drops to 25-40 psi and stays there, unless you hit 3,500 rpm, then BAM, it's back up to 75-90 psi. Odd, and you can feel it in the engine if you are feeling for it. The note of the engine changes just ever so slightly when the oil pressure spikes at 3,500 rpm.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2900186 - 02/09/13 07:04 AM Re: Pentastar 3.6 oil pressure [Re: The_Captain]
SteveSRT8 Offline
Loc: Sunny Florida
The new vane pumps are very different from the gerotor style we are used to in most cars.
Add in the variable displacement feature and you have a bizarre readout to study for the "new normal".
many newer engines are now using this style oil pump. Since all the variable cam timing and cylinder deactivation strategies are operated hydraulically by oil pressure the new engines require a larger volume of oil flow.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2900511 - 02/09/13 01:35 PM Re: Pentastar 3.6 oil pressure [Re: The_Captain]
cptbarkey Offline
Loc: texas
electric oil pumps... dont quite like the sound of that at all.
#2900605 - 02/09/13 03:05 PM Re: Pentastar 3.6 oil pressure [Re: cptbarkey]
caravanmike Offline
Loc: ohio
everything i read says it is chain driven! the elec part controls high or low pressure. from what i understand the motor can survive just fine on low pressure.
"A chain-driven, vane-type variable displacement oil pump adjusts the flow rate and pressure as commanded by the engine management system, which uses a solenoid to drive the pump into low or high pressure mode. For example, below 3,500 rpm, the pump conserves energy by using low pressure; at speeds over 3,500 rpm, the pump switches to high pressure."
Oils I use: Any 5w-30,5w-20 conventional
Page 1 of 2 1 2 >
