Was doing an oil change today (at -20C!) and after having poured most of a brand new, sealed 4.4 liter container of Castrol GTX 5W-30 into my car, I happened to look inside the container and noticed that there was a fair amount of small black particles at the bottom of the white plastic container. They range in size from just big enough to see to ~1mm in length. The larger particles are long and thin, very much like 1mm long pieces of human hair. As far as I could tell, they're mostly clinging loosely to the bottom of the container- there don't seem to be many/any particles suspended in the oil.
Has anyone out there ever seen this type of thing in new oil before? Any guesses as what it's likely to be? I called Castrol customer service and asked the same questions and was told to drain the oil and replace it, without even taking a guess as to what it might be. Replacing the oil at this point means an hour walk in -20C weather, which obviously is something I'd rather avoid if this is likely to either be nothing important or something the filter will pick up. I just can't recall seeing this in any of my previous couple hundred oil changes.
Thanks!
Thanks!
